Thread started 25 Feb 2011 (Friday) 20:59
580EX Flash Modifiers Accesory, What Do You Like?
Gizmo1137
Feb 25, 2011 20:59 |  #1
I am curious what flash modifying equipment you like and why? Gary Fong does not seem very good or will work for me. There are of course many others out there.
Best, Bruce
Joe ­ Ravenstein
Feb 25, 2011 21:51 |  #2
I use the Sto-Fen diffusers simply because the Gary Fong stuff "appears" to be made to extract the most money for the least amount of raw materials used. The Sto-Fens might be made from recycled milk jugs but they fit snugly and are suitably substantial in construction for my needs and uses. Most flash units have integral diffusion lens but they still put a hot spot on the subject. For every Sto-Fen supporter there are supporters for every other diffuser/modifier out there, make your own decisions.None are fiendishly expensive if you can't choose a clear winner.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
Mark1
Feb 25, 2011 23:03 |  #3
Depends on your definition of a flash modifier. I use everything from $3 stofen knock off to a 50 inch apallo.
however I also have 30 inch and 60 inch umbrellas. Micro apallo. 36 X 48 softbox. And once I used a 70 inch octo with a speedlight.
I dont classify anything as a flash modifier or not. I use what gets the job done.
Hoppy1
Feb 26, 2011 20:01 |  #4
Lots of threads on this.
It can get quite heated! This is a good one that seems to cover most points of view ;) https://photography-on-the.net/forum/showthre​ad.php?t=986948
5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
MSIGuy
Feb 26, 2011 22:19 |  #5
I'm a big fan of the Lumiquest stuff, specificly their FXtra gel holder and the Quik-Bounce.
Some cameras, some lenses, plenty of gaffer's tape and beer.
HughR
Feb 27, 2011 17:19 |  #6
I like Lumiquest as well. I've got the Softbox III, which strobist and also McNally were very enthusiastic about, and also the new Lumiquest Softbox LTp, which is about twice the surface area. Both attach easily and rapidly with velcro, and both do a very good job if they are positioned close to the subject for a head or head and shoulders portrait. If you want to cover a larger area from a greater distance, you need a larger, more expensive softbox. You can see Lumiquest at:
http://www.lumiquest.c​om/ (external link)
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
CousinMadness
Location: London, Ontario. Canada. Formerly Ayrshire Scotland.
Apr 06, 2011 10:35 |  #7
HughR wrote in post #11925184 (external link)
Thanks for the tip Hugh. I just ordered one of the Softbox III's through their website. It will come in handy for my off camera 580 EX II / Radio Popper.
Martin :)
I am the owner of Canada Lens Rentals. (external link)
Camera gear: About $65,000 worth LOL.
We'd love to see you on Facebook. (external link)
First SLR Zenith B, 12th Birthday 1972. Martin.
lazer-jock
Don't mess
Apr 06, 2011 15:13 |  #8
Would a nearby wall count as a modifier?  :p
I'm off lining my cage with newspaper.
My Gear List
nathancarter
Gallery: 32 photos
Apr 06, 2011 15:25 |  #9
Index card an' a rubber band.
I made a homemade beauty dish too, still getting the hang of using it. Haven't had a good opportunity to practice with it since I made it.
These days, my budget is close to zero, so I gotta make do with what I can.
pcj
Apr 06, 2011 15:29 |  #10
I have a few things I use - favorites are Cheetah Qbox's (24 and 16), cheap card flags and nearby walls, when I'm outdoors, I use a Lumiquest pocket bounce
I was talking to someone today who makes his own bubble wrap diffusers and loves the look!
7D (gripped) | GoPro Hero HD | Canon 70-200mm f/4 L | Tamron 28-75mm f/2.8 | 40mm f/2.8 | 85mm f/1.8 | 28mm f/1.8 | 3 * 600EX-RT - All gear
http://www.rt2photo.co​m (external link)
http://www.facebook.co​m/rt2photo (external link)
windpig
Chopped liver
Apr 06, 2011 15:58 |  #11
I use this often with my speedlights.
http://www.bhphotovide​o.com …_LiteDome_XS_So​ftbox.html (external link)
Go ahead, spin the wheel.
bluelight
Joined Jun 2010
Apr 06, 2011 16:04 |  #12
All I have is one 580EXII
I am using:
60 inch umbrella
28 Inch Softbox (apollo wescott)
Lumiquest small softbox when (I am covering events)
Bounce it off wall using index card
I have but not used yet (I intend to test this weekend)
Reflector
Grids (using PCB ones )
Home made snoot
I want
22" beauty dish
Gul
Canon 5D MarkII, 35mm F2.0, 50mm F1.4, 85mm F 1.8, 135mmF2.0L, a little bit of this and a little bit of that
3,465 views & 0 likes for this thread, 12 members have posted to it.
880 guests, 128 members online
