Thread started 26 Feb 2011 (Saturday) 08:31
Canon 60D Bu;b Exposure
rporzio
Feb 26, 2011 08:31 |  #1
Is the 60D capable of doing a timed bulb exposure or is it a manual process (I include using the remote as part of the manual process). I'm hoping there is a menu setting I'm missing that will allow me to set a 10 second opening for instance. Thanks, Ralph
Sdiver2489
Joined Sep 2009
Feb 26, 2011 08:53 |  #2
No, bulb is by definition a manual process....otherwise it would be called Tv mode.
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
va_rider
Feb 26, 2011 08:56 |  #3
a 10 second exposure can be done in Tv mode... up to 30sec in fact..
longer than 30sec, you need a remote... or, a piece of cork on a string and a rubber band.
Canon 5dmkIII, Sigma 15mm f/2.8FE; 35mm f/1.4; Canon EF70-200 f/2.8L IS II; --- YN560 x 7
I'm not a professional photographer, and I don't want to be.
rporzio
Feb 26, 2011 18:15 |  #4
so, did I miss something? Where is a 10-30 sec exposure defined in the menu system?
ImRaptor
Feb 26, 2011 18:18 |  #5
It's not in the menu system.
Go to TV mode or M mode and set your exposure time upto a maximum of 30 seconds.
Might I recommend opening up your manual and having a look there.
http://imraptor.devian​tart.com/ (external link)
Why yes, I am a jerk. Thank you for asking.
KhanhD
"I need a grip . . . on my life"
Feb 26, 2011 18:19 |  #6
In Tv or M mode, you can set your shutter at anywhere between 1/4000 and 30 seconds.......
Khanh Duong | KHDPhoto.com (external link) | flickr (external link) | facebook (external link)
iPhone 5s + Instagram (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 26, 2011 19:20 as a reply to  @ KhanhD's post |  #7
Between 1/8000 and 30s, actually. To go longer you set the mode dial at B, for cameras having that setting. The 60D doesn't, so instead you find bulb when you roll past 30s in the M mode.
Canon has a remote controller called TC-80N3. It allows programming longer exposures, used with the camera set to bulb mode. But it only works with cameras with the N3 remote control socket, not the E3 the 60D uses. But I think there are third party equivalents which have adapters for the connector.
Anders
rporzio
Feb 27, 2011 02:47 |  #8
ok guys thanks. I'll have another look at my manual and experiment with how to set exposure times. R.
Forphucsake
Feb 27, 2011 04:18 |  #9
apersson850 wrote in post #11920380 (external link)
Yeah it does. There is a lovely B right on the dial.
Nate - 60D (Gripped) | 17-40mm f/4.0L | 55-250mm IS | 50mm f/1.8 II
rporzio
Feb 27, 2011 07:02 |  #10
Did some test shots this AM and all of your advice makes more sense now. I did read the section of the manual for Tv and after a few tries got it to stay open the way I wanted it to. Now, I've got to set the stage and make plans for my shoot at night...
apersson850
Gallery: 35 photos
Feb 27, 2011 17:25 |  #11
Forphucsake wrote in post #11922071 (external link)
Sorry. You're right. That position used to be occupied by the A-DEP on these cameras. Had forgotten it was replaced with B on the 60D.
Anders
7,669 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is vinceisvisual
890 guests, 180 members online
