Thread started 26 Feb 2011 (Saturday) 17:42
Wireless Speedlite Trigger Kit/Speedlite 430 ex II
Snickerdoodle
Feb 26, 2011 17:42 |  #1
Help !
I have a Canon T1i and a Canon Speedlite 430 EX II, I purchased a RPS Studio Wireless Speedlite Trigger Kit to use the flash off camera. I can't get the camera to fire the trigger. I was wondering are these not compatible? The store where I purchased this trigger said this set up would work. Any ideas?????? Any help will be much appreciated.
Thank you,
Snickerdoodle
Canon 6D, Canon T1i, Canon T4i, Canon EF 70-300mm f/4-5.6 IS USM Lens, Canon EF-S 18-135mm f/3.5-5.6 IS, EF-S 18-55mm IS Lens, Canon EF 50mm f/1.8 Lens, Canon EF 100mm f/2.8 USM Macro Lens.
dedsen
Feb 26, 2011 17:54 |  #2
You have the transmitter and the receiver on the same channel?
Did you try NEW batteries?
Is there a test button on the receiver? Does pushing that fire your flash?
Is there a test button on the transmitter? Does pressing that fire flash?
Did you put your 430 in manual mode?
Snickerdoodle
Feb 26, 2011 17:56 as a reply to  @ dedsen's post |  #3
Yes to all of those....I used the test button and it worked fine...it is from the camera to the trigger that it isn't working.
Snickerdoodle
Feb 26, 2011 18:01 |  #4
Dale, I started over from scratch and it worked! Thanks so much for your help....it is much appreciated!
dedsen
Feb 26, 2011 18:02 |  #5
If you place the 430 in the hotshoe does that work. You may have a loose connection with the hotshoe.
Try holding down on the transmitter while in the hotshoe and see if that makes any difference.
dedsen
Feb 26, 2011 18:03 |  #6
great. Now do not break it again. :)
Snickerdoodle
Feb 26, 2011 18:23 |  #7
With me that will be impossible! :)
2,714 views & 0 likes for this thread, 2 members have posted to it.
1367 guests, 185 members online
