In an attempt to use my only 580 EXII wirelessly, I may have come across a problem.
On one of my 7D's, the Built in Flash is not popping up as it normally does.
Looking at the menu from the camera that is not allowing for built in flash to pop up, under menu
Flash Control
Built in flash func. setting
! This menu can not be displayed.
External flash is attached.
The same 580 on my new 7D it works fine.
The menu under
All options appear as always.
In attempt to rush, I must have changed something that I can not recall as the brain is getting older.
Both pop up flashes were working earlier and no error appears.
Looked in manual and no trouble shooting section.
Thanks.
