Thread started 28 Feb 2011 (Monday) 09:17
Calculating Back-Up Drive Capacity
kitjv
Feb 28, 2011 09:17 |  #1
Not sure if this is a valid question to ask. I am trying to determine an adequate storage capacity for a back-up portable HD. I use a Canon 400D & a Canon G11 to shoot RAW. Although the size of RAW files can vary, is there any basic rule-of-thumb regarding the average RAW file size? If so, I can get a rough estimate of the storage capacity I will need.
Thank you.
Wilt
Feb 28, 2011 09:55 |  #2
Have you considered simply aiming your camera at random scenes and shooting 10 photos, and looking at the file sizes, summing the sizes and dividing by 10 to calculate the average? (Keep in mind that shots at ISO1600 are noisier -- and larger-- than shots at ISO100) According to the Canon user manual, your 400D's average size for RAW file is 9.8MG
FeXL
Feb 28, 2011 11:10 as a reply to  @ Wilt's post |  #3
Have you considered that guesstimating your requirements is all moot any way? That it's all going to change with your next camera purchase? Or your next big project? Or whatever?
Really, with the price of hard drives these days, my suggestion is to purchase a toaster drive & three 1 TB drives. Load all your images on the first drive, backup to the second & keep them both in your home (the second in a closet, safe or someplace a thief won't be likely to see). Then, backup to the third & keep it offsite (parent or friend's house, safety deposit box, whatever). Update all as needed.
At that point you have 3 copies of everything, one for immediate access if something goes wrong at home & an offsite b/u if you end up with fire, flood, whatever.
When you run out of room, get another three 1 TB drives, rinse, repeat.
As far as how many images you can put on a drive, we use 1 TB drives & with our 1D MkII & IIN jpgs, RAWs & some edited images, there is about 200,000 images on a drive. I expect those numbers will drop with the Mk IV but it doesn't matter. When a drive gets full we'll just get another set of three.
MCAsan
Joined Jun 2010
Feb 28, 2011 11:20 as a reply to  @ FeXL's post |  #4
first...you can't have a drive with too much capacity. ;)
second...drives are cheap
So get at least a 1TB drive if not a 2TB drive.
Perhaps as important of a question is ...which interfaces to support. Portable drives can attach via:
FW 400
FW800
USB 2
eSATA
USB 3
What does your laptop or desktop support?
kitjv
Feb 28, 2011 11:22 |  #5
FeXL wrote in post #11929504 (external link)
As the OP, I should have been a bit clearer. My question is aimed at acquiring a portable external HD for back-up while traveling. Although I generally subscribe to the maxim that "bigger is better" when it comes to capacity, for traveling a week or two at a time I have no need for huge excess capacity.
Jon
Joined Jun 2004
Feb 28, 2011 11:29 |  #6
Take a look at Canon's file size information in each of your camera manuals. p. 166 for the 400D and 75 for the G11.
Jon
Cocker Spaniels
kitjv
Feb 28, 2011 11:46 |  #7
Jon wrote in post #11929635 (external link)
Jon: Good point. Just think how many unnecessary questions could be avoided if people like me took heed to the advise: "read your manual". :)
MCAsan
Joined Jun 2010
Feb 28, 2011 14:55 as a reply to  @ kitjv's post |  #8
size of all 2.5" drives is the same regardless of the capacity being anywhere from 320GB to 2TB these days. you will get more for your money for a 1TB or larger drive. And such a drive size would give you weeks of storage of raw files.
kitjv
Feb 28, 2011 16:42 |  #9
MCAsan wrote in post #11930930 (external link)
That's exactly what I am leaning toward. My original queston was driven by the fact that I have decided to swap my ol' Mac laptop for an iPad. But even the 64Gb iPad will have limited image back-up capacity. So for longer trips, a 2.5" external HD would make the most sense for me.
MCAsan
Joined Jun 2010
Feb 28, 2011 17:58 as a reply to  @ kitjv's post |  #10
I guess an Ipad needs a USB 2 external drive connected via a docking cable. Can you connect a CF card reader and an external HD at the same time to read/write?
kitjv
Feb 28, 2011 18:24 |  #11
MCAsan wrote in post #11931998 (external link)
Apple has a camera connection kit accessory to either connect an SD card directly to the iPad docking port or to connect a card reader to the iPad. However, the new iOS 4.2 operating system apparently has insufficient power to drive some card readers. The work-around seems to be a powered reader.
It is my understanding that the iPad will not support an external drive. Disappointing, but I have to remember than Apple didn't design the iPad to compete with a "real" computer.
MCAsan
Joined Jun 2010
Feb 28, 2011 18:37 as a reply to  @ kitjv's post |  #12
With those limitations...personal​ly I would go with a laptop.
hollis_f
Mar 01, 2011 05:35 |  #13
It's just a shame that you can't buy 2.5" drives with those sorts of capacity. Realistically 500GB is about all you can get - but that should still be enough for 20,000 7D raw files at 25 MB apiece.
For the OP - check out the Nexto ND2700 for 500GB of portable storage. Or, if you've got more cash, the Hyperdrive Colorspace iPad.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
MCAsan
Joined Jun 2010
Mar 01, 2011 06:30 as a reply to  @ hollis_f's post |  #14
The 2.5" drives are most used inside laptops or other devices. For those the max capacity commonly available is 500GB. For building an external backup HD, you can get 3.5" drives from 1-2TB in the $75-$175 range. An enclosure will be a few dollars more. Pick the enclosure for the desired external internfaces: FW400, FW800, eSATA, USB 2, USB3. If you want the external drive built for speed, put in a 7200rpm drive with a 64MB cache and use an enclosure for eSATA or USB3 (whichever your laptop or desktop will support).
FeXL
Mar 01, 2011 09:20 |  #15
kitjv wrote in post #11929587 (external link)
Ah, understood.
In that case, I have no further suggestions, as we use the laptop for said travel downloads (with a 2.5" FW external as backup).
2,346 views & 0 likes for this thread, 6 members have posted to it.
1037 guests, 107 members online
