Thread started 28 Feb 2011 (Monday) 19:25
50L with UU date code, focus shift issue?
eelnoraa
Feb 28, 2011 19:25 |  #1
I wonder anyone is using a 50L with UU date code (2006) ? In general, is it a good idea to buy a 5 years old L series lens? any concern?
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
SQMazda6
Feb 28, 2011 20:43 |  #2
The 50L is great just test it before you use it to make sure it is sharp. if not you can always send it in for a recal.
5D|BG-E4N|40D|BG-E2|15mm|28mm|35L|17-40L|50L|85 1.2L II|100mm macro|135L |70-200mm 2.8L| 580EX| Cybersync's| 1 bad bag problem!
1 X-wife
eelnoraa
Mar 01, 2011 11:09 |  #3
what would be a fare price for such a lens if condition is "exellent" claimed by the seller?
SQMazda6
Mar 01, 2011 11:11 |  #4
Depends on a lot. I would say around 1100-1400 but I am cheap.
1 X-wife
billppw350z
Mar 01, 2011 14:17 as a reply to  @ SQMazda6's post |  #5
While I have never had a “focus shift” problem in any real world picture taking situation since I got the 50L in December of 2006 (UU1000), I did get it to “focus shift” when I was micro adjusting it a few years ago. It shifts when I use the center auto focus point from f2.2 to f4 and from MFD to a little over four feet.
That being said…
All 50Ls “focus shift” (even the new ones) in the “danger zone” and way too many of the early ones are not as sharp as they should be at any aperture. As with any lens (but especially with this one), purchase it from a seller with a liberal return policy. Make sure you have it micro adjusted correctly, don’t worry about the focus shift, but do check it carefully for soft focus.
Hope this helps.
Bill
Regardless of the genre or medium, I just like capturing beauty and recording memories
billppw350z.smugmug.co​m/ (external link)
Sir_Loin
Mar 01, 2011 14:38 |  #6
The focus shift in the 50L is spherical aberration that won't disappear no matter when it was made. Because it doesn't use floating elements it won't get rid of the spherical aberration at close focussing distances in the aperture range 1.4 to 2.2. This impression that newer ones have eliminated it are false I'm afraid. You just have to be careful at closer distances.
You'll find that even the much vaunted Zeiss 50mm and 85mm lenses suffer from it more, but oddly not much is said about them?
EOS 1D4, 5D3, EF 24-70mm f/2.8L II, EF 70-200mm f/2.8L II IS, EF 50mm f/1.8 STM, EF 85mm f/1.2L II * EOS R6, RF 24-105mm f/4.0-7.1 * EOS M5, EF-M 11-22mm f/4.0-5.6 IS, EF-M 18-55mm f/3.5-5.6 IS, EF-M 55-200mm f/4.5-6.3 IS, EF-M 22mm f/2.0, EF-M 28mm f/3.5 Macro IS * FL-F 300mm f/5.6 FLUORITE, FD 55mm f/1.2 ASPHERICAL, FD 24-35mm f/3.5L, FD 50mm f/1.2L, FD 300mm f/2.8L, FD 50-300mm f/4.5L
eelnoraa
Mar 01, 2011 14:48 |  #7
billppw350z wrote in post #11937086 (external link)
That being said…
Hope this helps.
so something change in the production flow for newer 50L?
Unfortuntely, I am looking to buy used. This specific 50L is UU11 date code. according to the sellers, who is a professional photographer, he hardly use it, and this lens just came back from CPS. I wonder if I should give it a shot. What would be a fair price?
nicksan
Man I Like to Fart
Mar 01, 2011 15:20 |  #8
I would only buy this lens from a shop with a nice return policy.
I will never, ever buy this lens used unless it came with a warranty balance, but even then, if it's a "shifter" then there's really nothing much anyone can do about it.
2,984 views & 0 likes for this thread, 5 members have posted to it.
1367 guests, 164 members online
