So in my research for my new camera body, It really seam that the Canon 60D and the Nikon D7000 are comparable. What I can't find is the actual Canon 60D photo quality. How does the Canon 60D do with decent glass, say a 17-40mm L lens?
dharris Senior Member 844 posts Joined Apr 2005 Location: Fort Worth, TX More info | Mar 01, 2011 16:35 | #1 So in my research for my new camera body, It really seam that the Canon 60D and the Nikon D7000 are comparable. What I can't find is the actual Canon 60D photo quality. How does the Canon 60D do with decent glass, say a 17-40mm L lens?
macroshooter1970 Cream of the Crop 7,494 posts Likes: 2 Joined Jan 2007 Location: Arizona More info | Mar 01, 2011 16:40 | #2 Does just fine.
Vixen89 Goldmember 4,528 posts Likes: 14 Joined Aug 2010 Location: D-Town, TX More info | Mar 01, 2011 16:40 | #3 Have you checked this thread? There's a good number of posts with different L lenses but yes there's too many posts in there. xd I'm actively lazy!!
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Mar 01, 2011 18:22 | #4 dharris wrote in post #11937797 So in my research for my new camera body, It really seam that the Canon 60D and the Nikon D7000 are comparable. actually the Canon 60D has the edge -
SteveCampbell Senior Member 449 posts Joined Nov 2010 More info | The 17-40 is a great lens but to get the focal range of a wide angle you'll need something like a 10-22 on the 60D. Gear List
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Mar 01, 2011 19:16 | #6 dharris wrote in post #11937797 SWhat I can't find is the actual Canon 60D photo quality. http://www.dpreview.com/reviews/canoneos60D/
Mar 02, 2011 05:18 | #7 watt100 wrote in post #11938339 actually the Canon 60D has the edge - http://www.popphoto.com …/2011/01/tested-canon-60d At first I thought that comparison may be a one-off. But both Amateur Photographer magazine and PhotoRadar Frank Hollis - Retired mass spectroscopist
robtaylor22 Senior Member 425 posts Joined Nov 2010 Location: Utah More info | Mar 02, 2011 10:34 | #8 On a 60D the 17-40 is more of a normal zoom, not wide angle. The 60D is capable of very high resolution photos with noise well under control. There is a lot you can do with that resolution if you shoot RAW. In general the 60D is an excellent camera that is right for an advance amateur or enthusiast or as a back-up for a pro, it can do pro level work and Canon considers it Pro-Grade even though they market as Enthusiast. If it's in your budget I have no issues telling you to just buy it and don't look back.
Mar 02, 2011 10:47 | #9 robtaylor22 wrote in post #11942134 On a 60D the 17-40 is more of a normal zoom, not wide angle. The 60D is capable of very high resolution photos with noise well under control. There is a lot you can do with that resolution if you shoot RAW. In general the 60D is an excellent camera that is right for an advance amateur or enthusiast or as a back-up for a pro, it can do pro level work and Canon considers it Pro-Grade even though they market as Enthusiast. If it's in your budget I have no issues telling you to just buy it and don't look back. Thank you so much!
robtaylor22 Senior Member 425 posts Joined Nov 2010 Location: Utah More info | Mar 02, 2011 11:14 | #10 |
Just discovered the Canon 15-85mm IS, anyone with experience with this lens?
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 02, 2011 16:22 | #12 dharris wrote in post #11943726 Just discovered the Canon 15-85mm IS, anyone with experience with this lens? I have been using the Canon 60D with the 15-85 IS USM lens since the 60D arrived in early October. It is a spectacular combination. Up through ISO 1600 I can produce noiseless 12" x 18" prints in Photoshop CS5. In one print at ISO 200 and f/11, with zoom at 15mm, everything is sharp even in the extreme corners of the print. I'll try to send you a 100% blow-up of that tonight (no photos here at work). I have also used the lens with 60D very successfully at ISO 6400 for both theater photography and available light shots of candidates at political rallies; with a little noise removal in CS5 ACR, results are very good at 12"x18". In my opinion, it's a spectacular camera and lens combination. Hugh
Mar 02, 2011 16:41 | #13 HughR wrote in post #11944180 I have been using the Canon 60D with the 15-85 IS USM lens since the 60D arrived in early October. It is a spectacular combination. Up through ISO 1600 I can produce noiseless 12" x 18" prints in Photoshop CS5. In one print at ISO 200 and f/11, with zoom at 15mm, everything is sharp even in the extreme corners of the print. I'll try to send you a 100% blow-up of that tonight (no photos here at work). I have also used the lens with 60D very successfully at ISO 6400 for both theater photography and available light shots of candidates at political rallies; with a little noise removal in CS5 ACR, results are very good at 12"x18". In my opinion, it's a spectacular camera and lens combination. Awesome, thank you for your reply. Look forward to that image...
CH687 Mostly Lurking 18 posts Joined Mar 2011 Location: Southern California More info | Mar 02, 2011 17:46 | #14 I just got rid of my T1i and picked up a 60D the other day. What an improvement! I am amazed at all of the things you can do with the 60D. Iam using an EF S 55-250 and an EF S 18-55 and getting great shots. Mind you I'm no Ansel Adams.
HughR Senior Member 999 posts Joined Feb 2011 Location: Toronto, Ontario More info | Mar 02, 2011 19:15 | #15 dharris wrote in post #11944295 Awesome, thank you for your reply. Look forward to that image... Here are the images. For the record, I shoot RAW almost always and process in CS5. My love of photography is half shooting and half darkroom (now digital) to accentuate what I think is most important. First image is full image. Second is 100% of small patch in right corner. Image is of U of Toronto campus last November. Hugh
| Latest registered member is MWCarlsson 853 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
