A friend has a book (journal) which has sentimental value and he would like photos of each page (or maybe 2 pages at a time) for the possibility of publishing. What is the proper way to photograph a book?
Stefan
StefanA "The D is supposed to be where the S is!" More info | Mar 01, 2011 19:35 | #1 A friend has a book (journal) which has sentimental value and he would like photos of each page (or maybe 2 pages at a time) for the possibility of publishing. What is the proper way to photograph a book? 80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
Gizmo1137 Senior Member 960 posts Likes: 9 Joined Feb 2009 Location: Phoenix, AZ More info | Mar 01, 2011 20:18 | #2 Stefan A wrote in post #11938745 A friend has a book (journal) which has sentimental value and he would like photos of each page (or maybe 2 pages at a time) for the possibility of publishing. What is the proper way to photograph a book? Stefan Best procedure is to put your camera on a copy stand, using a macro lens or lens extension ring, with lighting on both sides at 45 degrees. You might also consider cutting a hole just large enough for your lens to fit on in black piece of cardboard large enough to hide your camera, to prevent a reflection of the camera showing up in the image. Best to photograph one page at a time with glass to keep page flat. Under each page you are photographing, place a black sheet of paper to prevent bleed through of any print or photographs. In absence of a copy stand, you can use a tripod, again with lighting on each side at 45 degrees. Best, Bruce
Jim60D Member 163 posts Joined Jan 2011 More info | Mar 01, 2011 22:09 | #3 Or, use a good quality, fast scanner at a reasonably high resolution. Use color if the pages have color, otherwise gray scale or B&W.
vraspagraphix Member 130 posts Likes: 8 Joined Jan 2011 More info | When copying any thing a good trick is to place a piece of black mattboard behind the page you are copying. This will prevent the other side of the page from bleeding through and help you keep the page straight. Your biggest problem will be keeping the binding from causing a shadow on the page. Handle it with care the pages will come out easier than you think. If you photograph you may need to polarize your light sources to prevent glare on the pages. If you use a scanner this won't be an issue.
CrystalWPhotography Senior Member 500 posts Likes: 2 Joined Jan 2011 Location: PA More info | Mar 02, 2011 07:59 | #5 I would say the best bet is to copy it using a high quality scanner. Taking a picture of a book like your friend needs is going to take alot of time and patience. Even scanning will take alot of time. Crystal
EL_PIC Goldmember 2,028 posts Likes: 1 Joined Dec 2009 Location: Austin Texas - Lucca Italy More info | Mar 02, 2011 08:17 | #6 Permanent banA book is 2D and unless you have a 2D lenes for your camera or better yet a rail camera .... EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Mar 03, 2011 19:55 | #7 Great - thanks for the tips. 80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
| Latest registered member is semonsters 1465 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
