I'm not a LR expert so take my advice with a pinch of salt.
However, I think this is fairly simple. Obviously, LR doesn't know what happens outside of its environment. So if you change the file location, you have to "tell" LR. I personnally know 2 options, there may be more or better ones.
One option is to move the folders from within LR through the left pannel in "Library". Simply drag & drop your folders from your current volume to your WHS. It takes a while, but at least LR doesn't lose track of your files.
The second option is to move your files via Windows Explorer, and then update the file locations within LR. On the same left pannel, you will get question marks next to your folders after having moved them to your WHS. Right click on each folder, select "update location" and choose the new one.
In both cases, I recommend you to try with a few images which you don't care about, and once you're confident, roll out with the rest of your library.
Good luck
