My wife is doing her first triathlon at the end of this month which gives me a good excuse to rent a lens for the event. I want to rent a telephoto lens that I would actually buy so here are my choices:
1a. 70-200 f/2.8L IS II + 1.4x
1b. 100-400L
2. 300 f/4L + 1.4x
I'm lumping the 70-200 and 100-400 together as a choice because they are similar size and weight to tryout. Although it will probably be sunny during the event (San Diego, CA) the 100-400 seems like it maybe too slow. This makes me lean toward the 70-200 and putting the 1.4x on it if needed. The 300 f/4L is another great, but different, option and would get the most reach with the 1.4x TC.
Part 2 of this question is which lens should go on which body. I have a 5Dc and 20D and I plan to use the 24-105L for the close range shots. I know the 20D will give me the reach for things like the swim and run, but for the bike portion which will be very fast the AI Servo of the 5D would probably perform better since it has the 6 additional AF points. However the 20D does 5 fps and the 5D only has 3 fps, but conversly the 20D will only do a 6 shot RAW burst where the 5D can do 17 RAW frames before the buffer fills. It's an option to switch lenses around between events if needed.
I've seen great sport shots from both and I never do this type of shooting so I'm hoping to get some suggestions. Thanks in advance
