IIs the 300 f4 is a good lens its like $1300 when the 2.8 is like 5000 any feed back will help thanks
jsims Mostly Lurking 16 posts Joined Dec 2009 More info | Mar 03, 2011 21:46 | #1 IIs the 300 f4 is a good lens its like $1300 when the 2.8 is like 5000 any feed back will help thanks
mikekelley "Meow! Bark! Honk! Hiss! Grrr! Tweet!" 7,317 posts Likes: 16 Joined Feb 2009 Location: Los Angeles, CA More info | Mar 03, 2011 21:48 | #2 YES IT IS A GOOD LENS Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Mar 03, 2011 21:56 | #3 YES Will | WilliamLiuPhotography.com
LightRules Return of the Jedi 9,911 posts Likes: 5 Joined Jun 2005 More info | Mar 03, 2011 22:11 | #4 mikekelley wrote in post #11952212 YES IT IS A GOOD LENS (especially for the price!) but i think i'd rather have a 100-400L in that range since we're already at f4. The 1-4 is a fine lens, but it's also at f5.6 at 300mm. And the 300 f4 IS is close optically to the zoom IS at 420mm f5.6.
Mar 03, 2011 22:14 | #5 i think a 300 prime would do me fine i am puting it on a 50d 1.6 crop and i already have a 70-200 2.8 so yall think the 300 or the 100-400
sudipto_roy Senior Member 508 posts Likes: 2 Joined Apr 2010 Location: Calcutta, India More info | Mar 03, 2011 22:21 | #6 If you want to go for birding then 300. If mammals then 100-400. 7D with 400 F 5.6 for birds
JIMMY369 Member 55 posts Joined May 2010 More info | Mar 04, 2011 15:10 | #7 jsims wrote in post #11952194 IIs the 300 f4 is a good lens its like $1300 when the 2.8 is like 5000 any feed back will help thanks I got this lens about a year and a half ago for shooting baseball, softball and HS football fortunatlely from the sidelines. I can tell you that it is a well built, very good, very sharp lens. Check out the photozone.de.com review.
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Mar 04, 2011 15:14 | #8 NO, it is a great lens. Probably the best ever lens for butterflies and dragonflies. GEAR LIST
bbss Senior Member 324 posts Likes: 6 Joined Aug 2009 Location: trondheim,norway More info | Mar 04, 2011 15:43 | #9 I just got me one of these. And must say I am very impressed. I really like lenses with a good MFD. It's light and sharp at f.4. Only miss weather sealing, as I thought there would be. A little disappointed on that on a lens that cost as much as the 50L.
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info | Mar 04, 2011 16:11 | #10 What about 300/4 vs 70-200/2.8 II + 1.4x ? 1Dx, 5D2 and some lenses
dgsphoto Senior Member 421 posts Joined Dec 2010 Location: SFO Bay Area More info | Mar 04, 2011 16:52 | #11 The 300/4 is a great lens and even a greater value!
rjx Goldmember 2,670 posts Likes: 2 Joined Oct 2007 Location: Santa Clara, California More info | Mar 04, 2011 17:25 | #12 The 300/f4 is a great lens. "It doesn't matter what camera you have if your photography has nothing worthwhile to say"
Mar 04, 2011 19:40 | #13 thanks for all of the veary good hands on knolage and advice that yall have passed on to me i value it alot thanks to u yall !!!!!!!!!!!!!
nightcat Goldmember 4,533 posts Likes: 28 Joined Aug 2008 More info | Mar 04, 2011 19:58 | #14 Its a great lens at a reasonable price.
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Mar 05, 2011 12:42 | #15 300mm f4L IS is a great lens. Hand holdable. Good IQ, fast focus, and its I.S. works pretty well. I use it on both crop sensor and full frame cameras. It is one of Canon's earliest I.S. lenses (1997), so it's not one of the newer versions of I.S. Still, depending upon your hand holding skills, it's probably good for two to three stops. But if used locked down on a tripod, you're supposed to manually turn off I.S. on this lens, or it can get into sort of a feedback loop that actually induces motion blur rather than stopping it. The age of this lens is also why it doesn't have the silly little rubber o-ring on the mount that Canon calls "weather sealing". They started putting those on some of the L-series around 2000 or 2001, if memory serves. If you really wanted that o-ring weatherseal on it, maybe the bayonet mount from one of the other lenses (such as the 70-200/2.8 I.S.) that have it could be transplanted. Frankly the o-ring wore off on my 70-200/2.8 I.S. years ago and it doesn't seem to make any difference at all. Using that 70-200/2.8 I.S. ("classic"), too, I definitely prefer the 300/4 instead of adding a 1.4X to the zoom. I'm a fan of prime lenses for anything longer than 200mm (however might have to break that personal "rule" for the new 200-400 Extender!) I'm not really interested in a push/pull zoom like the 100-400, either... another personal preference... a lot of folks really like that zoom, which is similar in size and weight to the 300/4. The Siggy 120-400 O.S. seems interesting and is a traditional two ring zoom, seems comparable to the Canon 100-400 for IQ, but I haven't used either of them. Neither of the zooms are practical to use with any teleconverter, but both offer 400mm (altho it appears images tend to get a little softer at the long end of the zoom, in both cases). I also use 300/2.8 I.S., but that's largely a tripod lens, can't be handheld for very long. Unless it's about the only lens you're toting, the f2.8 is also not a lot of fun to backpack any significant distance (such as around a Mazda/Laguna Seca race track). The f2.8 gives absolute top, uncompromising IQ... But the 300/4 comes closer than it should to matching it, considering it's about 1/4 the price. The 300/4 also works quite well with 1.4X teleconverter (I'm using the Canon Mark II). Of course, the 300/2.8 takes both 1.4X and 2X teleconverters very well. The 300/4 is really only usable with 1.4X. Anything short of a 1-series camera, you lose AF and have a dark viewfinder to try to manual focus with a 2X on it... So I haven't really tried it at all. (I have used 2X on a 500mm with some success, manually focusing.) I bought my 300/4 I.S. lightly used a year or two ago locally off Craigslist. The only sign it's used is that someone wrote "300mm" in permanent marker on the lens case (D'oh! :rolleyes . If you have doubts, all these lenses are pretty widely available to rent... It might be worth trying before buying. Alan Myers
| Latest registered member is NekoZ8 1242 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
