well I have the doubt, according to your experience, which parameters does affect canon RAW files. ?? I mean highlight tone priority, creative styles, sharpness,NR,etc...
CyberManiaK Senior Member 673 posts Likes: 1 Joined Jan 2009 Location: So.Cal More info | Mar 04, 2011 14:27 | #1 well I have the doubt, according to your experience, which parameters does affect canon RAW files. ?? I mean highlight tone priority, creative styles, sharpness,NR,etc... Carlos
nepali Senior Member 986 posts Likes: 4 Joined Sep 2010 Location: Dallas, TX More info | Mar 04, 2011 16:12 | #2 CyberManiaK wrote in post #11956252 well I have the doubt, according to your experience, which parameters does affect canon RAW files. ?? I mean highlight tone priority, creative styles, sharpness,NR,etc... Someone correct me if I am wrong, but, the camera uses the parameters to display the image on the LCD and DPP uses the parameters as a starting point.
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Mar 04, 2011 16:15 | #3 Basically, none.
5DM2User Member 76 posts Joined Jan 2011 Location: North Pole More info | Shoot in RAW : Certain settings will be ignored. 2X Canon 1Dx, 2X Canon 5D Mark III, 2X 24-70 f2.8 II, 2X 70-200 f2.8 IS II, 2X 580EX II, L-24mm, L-35mm, L-50mm, L-85mm, A Mack truck full of Pro-Photography stuff, A bunch of Malinois to protect and serve. A Hummer to go where i want to go, to take photographs....
gonzogolf dumb remark memorialized More info | Mar 04, 2011 16:27 | #5 Raw files contain all the data from the sensor so none of the style settings are set in stone, only exposure settings.. Some raw converters use the style settings as a starting point but they are just there for reference.
Mar 04, 2011 16:30 | #6 Yeah I have been shooting RAW since i started on DSLR 3 years ago, but I was wondering which parameters do affect Canon RAW's (i have been shooting canon 1 month only). I know that some parameters are only for the preview jpg, but wondering if something does affect the raw. For example on the D7000 even if you have NR OFF even on RAW, there is a just a bit of NR of ISO 1600 and above. On my ex alpha it wasnt anything taking into the Raw. Of course developing the raw in a third party software. Carlos
krb Cream of the Crop 8,818 posts Likes: 8 Joined Jun 2008 Location: Where southern efficiency and northern charm come together More info | Mar 04, 2011 16:35 | #7 |
tonylong ...winded More info | Mar 04, 2011 17:34 | #8 CyberManiaK wrote in post #11956252 well I have the doubt, according to your experience, which parameters does affect canon RAW files. ?? I mean highlight tone priority, creative styles, sharpness,NR,etc... There are a couple settings that affect how some Raw processors might render your images, although there is some mystery and confusion in the various settings. Tony
jase1125 Goldmember More info | Mar 04, 2011 17:37 | #9 Good explanation and write up Tony Jason
Mar 04, 2011 21:34 | #10 Thanks Tony.. Thats why i'm asking because I do ETTR, but i'm having a hard time,to preserve details on the highlights, so i'm looking to find which settings will represent the most accurate histogram of the RAW and not the JPG.. Because i can't believe that sometimes I cant recover 1 stop of highlights, i'm using a 60D, and on my ex alpha A300 I was able to recover 2 stops with out a problem. But on the 60D i don't know if that is because the dynamic range is to short or what, but the sensor got saturated very easy and the results as you know posterized highlights. Carlos
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Mar 04, 2011 22:20 | #11 CyberManiaK wrote in post #11958454 Any tips here? Look for something called UniWB.
tonylong ...winded More info | Mar 08, 2011 12:38 | #12 CyberManiaK wrote in post #11958454 Thanks Tony.. Thats why i'm asking because I do ETTR, but i'm having a hard time,to preserve details on the highlights, so i'm looking to find which settings will represent the most accurate histogram of the RAW and not the JPG.. Because i can't believe that sometimes I cant recover 1 stop of highlights, i'm using a 60D, and on my ex alpha A300 I was able to recover 2 stops with out a problem. But on the 60D i don't know if that is because the dynamic range is to short or what, but the sensor got saturated very easy and the results as you know posterized highlights. Any tips here? To get the most accurate histogram in the camera you need to lower the in-camera contrast and saturation levels all the way -- set your Picture Style to Neutral or Faithful and then lower those settings. Tony
fstop72 Junior Member 21 posts Joined Sep 2009 Location: Huntington Beach CA More info | Mar 10, 2011 18:47 | #13 To get my ISO expansion scale to start at 50 = "L" ISO for some night light shots. I had to disable the HTP.
tonylong ...winded More info | Mar 11, 2011 17:19 | #14 fstop72 wrote in post #11997589 To get my ISO expansion scale to start at 50 = "L" ISO for some night light shots. I had to disable the HTP. I didn't know that, but people also should know that ISO 100 is disabled as well with HTP -- you set it to "iso 200" and it captures the ISO 100 signal, but you can't set it to ISO 100. Tony
| Latest registered member is semonsters 1469 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
