Thread started 25 Sep 2005 (Sunday) 02:07
What Batteries Are You Using In Your Flash
m3incorp
Sep 25, 2005 02:07 |  #1
My 420EX seems to take forever for the pilot light to come on and then a long time in between flashes using 1800mAh rechargeables. Guess I might have to go out and buy some higher rated ones. Anyone use the CPE2 battery pack? What kind of recycle times are you experiencing.
7D, 10D, Canon EFS 18-55mm modded
Canon EF 50mm, Canon 85mm 1.8, Tamron 17-50mm F/2.8 XR DiII VC
Canon EF 70-300mm, 70-200 F4 L
, Canon 430ex ii Speedlite.
peterdoomen
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
Sep 25, 2005 02:57 |  #2
I use a set of GP 2100 and one of GP 2300 mAh for my 420EX.
Recharge times are low if the batteries are fresh (typically I'd say for 250 shots in varying light circumstances). Recharge times increase when batteries are near empty, so I always carry an extra set with me.
PeteR.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock (external link) - Make your own Tabletop Studio (external link)- Glass Buying Guide (external link)
My ShutterStock Gallery (external link)
etaf
Sep 25, 2005 04:12 |  #3
i use GP 1600mAh Ni-MH in a 550EX and they are great {that was the highest Mah rating I could get a few years ago - and i have no reason to want to change them }
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
gmen
Joined Aug 2004
Sep 25, 2005 05:14 |  #4
The CP-E2 pack would speed up your recycle times but sadly it doesn't work with the 420EX - from memory, it's only compatible with the 580EX, 550EX, 430EX and MR-14EX.
Your best bet, as others have Said, is to try some higher capacity rechargeables... 2700mAh versions are available, for example: http://www.bhphotovide​o.com …ails&Q=&sku=384​462&is=REG (external link)
---- Gavin
TGSPhoto Editorial Sports Photography (external link) | TGS Blog (external link) | TGS Twitter (external link) | TGS Sportsshooter (external link) | TGS Tweets (external link) | TGS Facebook (external link) | LinkedIn (external link)
blundar
Sep 27, 2005 08:08 as a reply to  @ gmen's post |  #5
I use NiMh 2500mah Energizer rechargables. I usually buy them in 10 packs because they are cheaper that way.
Antonio Cotto
GemPhoto
http://www.myspace.com​/gemphoto (external link)
http://ujenatalent.com​/photographer/11253.ht​ml (external link)
http://www.modelmayhem​.com/member.php?id=886 (external link)
Agger
Sep 27, 2005 08:14 as a reply to  @ blundar's post |  #6
2400 ni mh in my 580 works fine recycle is pretty damn quick :cool:
Canon 10d & 20d Speedlite 580 ex
Canon 1.4 Extender Canon 17-40 L f 4
Canon 85 L f 1.2 Canon 100 f 2.8 macro Canon 135 L
Canon 180 L f 3.5 macro Canon 200 L f2.8 Canon100-400 L f4.5-5.6:cool:
tim
Light Bringer
Sep 27, 2005 09:06 |  #7
I use a range of batteries from generic 2000mah NiMH cells to 2800 Power2000 cells, all work well. I have the CPE-3, the full recharge time cuts drops from about 6 seconds to about 2 seconds, but I don't use it because the cord's not long enough to attach to my belt if the flash is on a bracket. Normally it mounts under the camera, but I have a grip there.
mediamanrit
Sep 27, 2005 16:50 |  #8
I use 2800mAh Power2000s with my Sigma 500...I dunno the exact time, but it's darn fast...it hasn't not kept up with me yet.
Digital Rebel XT (350D), w/ Sigma EF 500 DG Super
EF 70-200 f/2.8 IS USM L, 50mm f/1.8 II
Sigma 50-500 f/4-6.3 EX DG/HSM, 24-70 EX DG Macro, 10-20 EX DC HSM
pcDigiMan
Sep 27, 2005 18:48 |  #9
Was using ni mh 2300 mah with no issues but I got tired of charging them. I recently threw in my 580EX a set of Energizer Lithium Ion batteries that were laying around. I hope they will last a long time. Lighter in weight and they perform well in low and high temperature. Expect them to outperform alkaline batteries. If you have an extra set I believe they have a 15 year shelf life.
Cheers,
Bob - A Swell Guy
7D, 20D, EF-S 17-85mm f4/5.6 IS, EF 24-70mm f/2.8 L, EF 70-200mm f/2.8 L IS, 2x II, 580EX, 430EX (x3).
Bosman
Sep 28, 2005 08:07 |  #10
Actually I use EnergizerMax non-rechargeables. I was wondering if anyone else did?
The way I figure it, the batteries are like 8 for under $5, I keep four in the flash and four in my bag. Canon says you should get like 200-300 flashes I believe. That seemed pretty good and I have the fresh set ready if necessary. No need to worry about recharging. Also, don't you get the same amount of flashes out of rechargables? I mean I realize that a camera chews up regular alkalines pretty fast but I didn't think a flash would.
If I am missing something here, please let me know.
Joe
Rebel XT with grip
Tamron SP AF28-75mm F/2.8 XR Di LD Aspherical (IF)
Canon 18-55 3.5-5.6
Canon 50 1.8
420EX
Domke
F-3X
Domke F-5XB
René ­ Damkot
Sep 28, 2005 09:18 |  #11
NiMh's recharge the flash waaay faster, are cheaper on the long run, and more environment-friendly...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
tim
Light Bringer
Sep 28, 2005 09:22 |  #12
NiMH last longer, and I use 4-5 sets per wedding. With Alkaline i'd be forever changing batteries, that'd suck.
Curtis ­ N
Master Flasher
Sep 28, 2005 09:24 as a reply to  @ Bosman's post |  #13
I switched to NiMH for my little P&S camera several years ago and was amazed at how long they lasted compared to Energizers and Duracells.
Even a cheap, low-powered NiMH will be STILL GOING!, long after the Energizer bunny has died.
m3incorp
Sep 28, 2005 15:08 |  #14
Had my 2500mAh Powermax's shipped over and all is fine now. Thanks.
BrianEE93
Sep 28, 2005 18:24 |  #15
Sams Club has 2500mah energizers for $15 for an 8pack. For a little more you can get a charger.(slow 12 hour charge) No problem just plan ahead.
EOS 20D w/ BG-E2
Canon EF-24mm f/2.8
Canon EF-50mm f/1.8 II
Canon EF-85mm f/1.8 USM
Sigma 24-70 EX DG Macro
Sigma 50-500 EX DG HSM w/1.4x EX
Sigma EF-500 DG Super w/BB
Manfrotto Mono(681B) & Tripod(3021PRO) w/Gimbal
Image Tank G2 OTG 40GB
2,237 views & 0 likes for this thread
Latest registered member is Wahama90
1012 guests, 301 members online
