This isn't clear to me.
Let's say you have a lens that is sharp in the middle but the edges suck.
Does this improve if you mount it on a crop sensor body?
uOpt Goldmember 2,283 posts Likes: 3 Joined Jun 2009 Location: Boston, MA, USA More info | Mar 05, 2011 14:20 | #1 This isn't clear to me. My imagine composition sucks. I need a heavier lens.
macroimage Goldmember 2,169 posts Likes: 2 Joined Aug 2007 More info | Mar 05, 2011 14:26 | #2 Not necessarily because to get the same depth of field on a 1.6x crop camera, you would open the aperture by 1+1/3 stops or to say it the other way, when on full frame, you would stop down 1 and 1/3 stops further to get the same result with a 1.6x longer focal length when taking the picture from the same distance.
Mar 05, 2011 14:46 | #3 uOpt wrote in post #11961791 This isn't clear to me. Let's say you have a lens that is sharp in the middle but the edges suck. Does this improve if you mount it on a crop sensor body? That's quite a vague question really. If you put it on a crop sensor and don't change anything else, you will get just the central portion of the image you had with a FF camera. Often, on lenses where the quality falls off as you move away from the optical axis, the central part of the image is "better". - you just don't get edges (i.e. the sucky bits) so the part you do get can be better. If that's the image you wanted, that's fine. So it basically depends on how much the edges suck - they get better if you stop down. There are too many variables for a simple answer beyond this kind of thing. Or do, you have a more specific question ?
Mar 05, 2011 14:52 | #4 No, I was just thinking too complicated after making diagrams on paper. My imagine composition sucks. I need a heavier lens.
macroimage Goldmember 2,169 posts Likes: 2 Joined Aug 2007 More info | Mar 05, 2011 15:11 | #5 uOpt wrote in post #11961935 Does a lens with lousy edge sharpness really get better as you narrow down aperture? I am talking about edge sharpness problems for objects that are in focus (have the same distance as the thing you focus on). I don't think so. If the glass at the edges just isn't shaped precisely enough you can't focus that up, no? That isn't how optical imaging works. All of the glass is used for all parts of the image. There is a light ray from each point on the subject, through each part of the lens which is then focused to a point on the sensor. Items at the edge of your picture don't just use the edge of the glass. As you close down the aperture, you are reducing the rays that are striking the lens elements at different angles so that all of the rays pass through the smaller and smaller iris and excludes the other rays that are at different angles. This does sharpen the edges of the image quite a bit.
Mar 05, 2011 15:50 | #6 Oh I knew that part. But what happens if the individual glass elements are made cheaply and only the center is actually at the angles you want and the outer parts of the glass are "off"? I think that must be the reason why some lenses have better edge sharpness than others. My imagine composition sucks. I need a heavier lens.
Mar 05, 2011 15:59 | #7 macroimage wrote in post #11961813 Not necessarily because to get the same depth of field on a 1.6x crop camera, you would open the aperture by 1+1/3 stops or to say it the other way, when on full frame, you would stop down 1 and 1/3 stops further to get the same result with a 1.6x longer focal length when taking the picture from the same distance. So, for example, a 70-300mm f/4-5.6 zoom that would be used at 188mm f/5.6 on the crop camera would be used on the full frame camera at 300mm f/9 to make the same image. Why would I take the aperture from 5.6 to 9.0 on the FF? f/5.6 should give me the same light/exposure time at 188mm and 300mm. The f-stop already compensates for the different focal length. My imagine composition sucks. I need a heavier lens.
macroimage Goldmember 2,169 posts Likes: 2 Joined Aug 2007 More info | Mar 05, 2011 16:06 | #8 You would go from f/5.6 to f/9 to give the same aperture diameter at 188 and 300mm to get the same depth of field at the same distance. It isn't to get the same exposure brightness, it is to get the same composition. To get the same shutter speed, you would need to go from ISO 100 to ISO250 on full frame to compensate for the reduced brightness at f/9 compared to f/5.6.
Mar 05, 2011 16:18 | #9 macroimage wrote in post #11962267 You would go from f/5.6 to f/9 to give the same aperture diameter at 188 and 300mm to get the same depth of field at the same distance. It isn't to get the same exposure brightness, it is to get the same composition. To get the same shutter speed, you would need to go from ISO 100 to ISO250 on full frame to compensate for the reduced brightness at f/9 compared to f/5.6. It would be a bit silly to compare 188mm f/5.6 on a crop camera to 300mm f/5.6 on a full frame since the latter would give much shallower depth of field and look different. Are you sure you need to keep the absolute aperture diameter the same to get the same depth of field between 188/crop and 300/FF? My imagine composition sucks. I need a heavier lens.
macroimage Goldmember 2,169 posts Likes: 2 Joined Aug 2007 More info | Mar 05, 2011 16:49 | #10 Consider the case of just cropping the final image from the full frame camera. In doing so, you have reduced the depth of field when viewing at the same size since you had to magnify the image 1.6x more to reach the same print or viewing size. The blur is magnified further.
Mar 05, 2011 17:09 | #11 Hmm, that makes more sense. My imagine composition sucks. I need a heavier lens.
Mar 06, 2011 12:49 | #12 Yeah it's pretty easy to see when testing. 25mm shot at f/4 and then cutting out an area that would be 40mm focal length gives very roughly the same bokeh as shooting at 40mm with f/7.1 My imagine composition sucks. I need a heavier lens.
Mar 06, 2011 13:41 | #13 Sounds like you mean depth of field or amount of out of focus areas in the image.
Mar 06, 2011 14:09 | #14 Right. Sorry. My imagine composition sucks. I need a heavier lens.
macroimage Goldmember 2,169 posts Likes: 2 Joined Aug 2007 More info | Mar 06, 2011 16:19 | #15 Sorry about that.
| Latest registered member is EBiffany 1594 guests, 96 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
