I see that AlienBees sells gels & gel holders - but they're not cheap. Wondering if anyone has rigged a DIY solution?
Christina Senior Member 633 posts Joined Jan 2007 Location: Pittsburgh More info | Mar 06, 2011 07:26 | #1 I see that AlienBees sells gels & gel holders - but they're not cheap. Wondering if anyone has rigged a DIY solution? Christina - Pittsburgh Wedding Photographer
Shamir Senior Member 508 posts Likes: 1 Joined Oct 2008 Location: Santo Domingo More info | Mar 06, 2011 08:23 | #2 there are this transparent-colored folders. they sell up for about 50 cents in my country.. you can get few of them and fold them few times... that should do the trick Shamir
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 06, 2011 09:12 | #3 The significant advantage of using the AB UMF (LightMod Mainframe) to support gels is that it is vented for cooling. If you use the standard reflectors and tape a gel over them, you could easily melt the gel if you are using the modeling lamp. Skip Douglas
k.CHU Goldmember 1,115 posts Joined Mar 2008 Location: City of Angels More info | Mar 06, 2011 10:14 | #4 Kevin Chu Photography
Mar 06, 2011 18:02 | #5 SkipD wrote in post #11965929 The significant advantage of using the AB UMF (LightMod Mainframe) to support gels is that it is vented for cooling. If you use the standard reflectors and tape a gel over them, you could easily melt the gel if you are using the modeling lamp. Good point. I very rarely use the modeling lamp though. How do you attach them? Christina - Pittsburgh Wedding Photographer
k.CHU Goldmember 1,115 posts Joined Mar 2008 Location: City of Angels More info | Mar 06, 2011 18:17 | #6 alienbees flash units come with the nylon clip to attach gels on it, i simply put one on top and one on bottom of the standard reflector that comes with it. Kevin Chu Photography
| Latest registered member is ealarcon 507 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
