so i want to know how do i get this color? and the effect from this background
http://www.spotthenight.com …ixtape-bridgezmag.com.jpg![]()
ddaayynnee Senior Member 381 posts Joined Mar 2010 Location: new york, long island More info | Mar 06, 2011 17:28 | #1 so i want to know how do i get this color? and the effect from this background
TheHardWay Senior Member 542 posts Joined Jun 2009 Location: El Segundo, CA More info | Mar 06, 2011 17:30 | #2 If that's not your photo, you can't post it. Post a link to it instead. Canon 5D & 40D | 70-200mm f/2.8 L IS | 16-35mm f/2.8 L | 10-22mm f/3.5-4.5 | 50mm f/1.8
ddaayynnee THREAD STARTER Senior Member 381 posts Joined Mar 2010 Location: new york, long island More info | Mar 06, 2011 17:36 | #3
tonylong ...winded More info | Mar 06, 2011 21:45 | #4 You will need to delete the photo from your original post -- you can replace it with the link -- just click the edit button, delete the IMG link and replace with the URL. Tony
ddaayynnee THREAD STARTER Senior Member 381 posts Joined Mar 2010 Location: new york, long island More info | Mar 06, 2011 21:53 | #5 |
tonylong ...winded More info | Mar 06, 2011 22:19 | #6 ddaayynnee wrote in post #11969996 i STILLLLL get none of reply how to do this even i gave a link on 2nd post............... Well, give it some time, people have to look and ponder and in the end it will only be guesses! Tony
ddaayynnee THREAD STARTER Senior Member 381 posts Joined Mar 2010 Location: new york, long island More info | Mar 06, 2011 22:25 | #7 |
tonylong ...winded More info | Mar 06, 2011 22:30 | #8 Well, what software do you have? It looks to me like it's mostly a greyscale conversion with a touch of color added back to the face, but like I said it's just a guess. The actual creator of the image will have the "info"! Tony
ddaayynnee THREAD STARTER Senior Member 381 posts Joined Mar 2010 Location: new york, long island More info | Mar 06, 2011 22:48 | #9 |
tonylong ...winded More info | Mar 07, 2011 01:00 | #10 Well, with Lightroom, try doing a total desaturation and then brushing some very mild saturation over the face. With Photoshop, you can do it with layers -- add a B&W conversion layer with a mask filled with black, and then brush a very low opacity/gray area over the face to bring out a bit of color. Tony
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Mar 07, 2011 01:24 | #11 In Photoshop, I would do a black-and-white conversion layer (any one you fancy - desat, BW, gradient map, etc) then reduce its opacity to around 30-50%. Then add a Gradient Map layer (black to bright green), change its blend mode to Soft Light, and reduce its opacity also to 30-50%.
kirkt Cream of the Crop More info | Mar 07, 2011 11:31 | #12 You can also split tone the image, or duo /-tri tone the image. You can also use the Color Balance adjustment and pull your colors toward the desired endpoints, letting Photoshop decide what is shadow, midtone and highlight. Kirk
Peano Goldmember 1,778 posts Likes: 133 Joined Aug 2007 More info | My steps:
Peano Goldmember 1,778 posts Likes: 133 Joined Aug 2007 More info | Mar 07, 2011 14:00 | #14 ddaayynnee wrote in post #11970205 i need info asap so i can finish my work, i kept trying, trying and trying so it never came out good as this shots There's a lot more to the picture you linked to than modifying color. Much more. ---
ddaayynnee THREAD STARTER Senior Member 381 posts Joined Mar 2010 Location: new york, long island More info | Mar 07, 2011 18:00 | #15 |
| Latest registered member was a spammer, and banned as such! 2643 guests, 163 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
