Thread started 06 Mar 2011 (Sunday) 22:10
Slightly smaller than a Domke F2
f8andBeThere
Gallery: 12 photos
Mar 06, 2011 22:10 |  #1
I'm currently working out of an old Domke F2 that's been a great bag. I'm looking for a Domke that's just a little smaller but will still hold an ungripped 7D with a 70-200 f2.8 attached, one other short lens loose, and a flash. Wondering if one of the F3x series would work? Thanks
hfgarris
Mar 06, 2011 22:49 |  #2
I would look at the Domke F3X,
Think Tank Retrospective 10 or 20,
and Think Tank Urban Disguise 35.
Jon
Joined Jun 2004
Mar 06, 2011 22:50 |  #3
F3x (vertically), F6 (horizontally) or maybe the F4 AF. I use the F1x, F2, F3x, F5b, F7 Double AF or F802 mostly. The F3x is my one body/two lens solution.
Jon
Cocker Spaniels
CitizenMinistry
Mar 06, 2011 23:01 as a reply to  @ hfgarris's post |  #4
F-3x is too short to accomodate a 70-200 2.8L attached to a body.
Staszek
Mar 06, 2011 23:11 |  #5
CitizenMinistry wrote in post #11970464 (external link)
I agree. The 70-200 won't even fit with the hood ready to shoot. I use the f-3x when I dot need the 70-200. If I need the white lens, it's the f-2.
SOSKIphoto (external link) | Blog (external link) | Facebook (external link)| Instagram (external link)
Shooting with big noisy cameras and a bag of primes.
f8andBeThere
Gallery: 12 photos
Mar 06, 2011 23:27 |  #6
Sounds like I may do best to stick with the F2 and just unload some of its load when I want to travel lighter. It is perfect for carrying the 70-200 attached (horizontal in the bag w/3-pocket insert)
hfgarris
Mar 06, 2011 23:51 |  #7
If you want to carry the 70-200 f/2.8 mounted to the camera, another lens or 2, and a flash:
Think Tank Retrospective 10 or 20 (the 10 will barely fit, 20 is great)
They will work with a gripped body as well. I know you said "Domke", but these will work too. The Retrospective is very Domke-like, but I think better sized for current sized cameras and lenses.
-howard
Staszek
Mar 06, 2011 23:53 |  #8
f8andBeThere wrote in post #11970611 (external link)
Sounds like you're not using the hood. If that's the case, the F-6 should work. It will accept your insert IIRC.
peter_n
Mar 07, 2011 07:26 |  #9
Yes, the F-6. It's even called "the little bit smaller bag". You do lose the F-2 end pockets with the F-6.
~Peter
lucifer06
Mar 07, 2011 08:24 |  #10
Maybe u should take a look at the f-831. Holds my 50d with 24-70 with hood in shooting position.
Jon
Joined Jun 2004
Mar 07, 2011 12:56 as a reply to  @ lucifer06's post |  #11
Only if you want the hood extended while it's in the bag. If that's the case, you'll either have vast amounts of extra space in the bag or a very specialized bag because of the 3" or so it adds to the length of the lens.
F3x with 100-400; F2 with 70-200 2.8 IS. 100-400 on a 5D; 70-200 on a 20D. The F3x has a 580EX in one of the outside pockets; there's enough room for another lens or two (up to the 24-70 2.8) alongside the 100-400 or 70-200.
Staszek wrote in post #11970726 (external link)
Nope. The F6 uses a separate, shorter, set of inserts. It's not as deep as the other Domkes, so can't handle the 720-230 insert.
Jon
Cocker Spaniels
Staszek
Mar 07, 2011 14:21 |  #12
Jon wrote in post #11973703 (external link)
Thanks for clarifying that. One thing I don't like about the f-6 is the smaller shoulder strap.
f8andBeThere
Gallery: 12 photos
Mar 07, 2011 23:14 |  #13
I'm used to packing the 70-200 mounted with the hood reversed. Thanks for all the ideas, folks.
3,620 views & 0 likes for this thread, 7 members have posted to it.
1060 guests, 109 members online
