Was wondering when you do test to check for front/back focusing, do you shoot at minimum distance or at a certain distance?
I took a few shots with a recently bought used Tamron 28-75mm @ 2.8 from minimum focus distance the other day and found that at 28mm the lens back focus a little, while at 75mm it's spot on.
. I actually like using this lens at the wide end more.
