Thread started 10 Mar 2011 (Thursday) 12:40
Couple of Evo's From the Budweiser Car Show
weavedesigns
Mar 10, 2011 12:40 |  #1
Here are some photos I took awhile back at the Budwieser Car Show, C&C please trying to get better with editing and photo overall haha
IMAGE: http://farm6.static.flickr.com/5212/5515548662_757f4f22d1.jpg
IMAGE LINK: http://www.flickr.com …/60446252@N07/5​515548662/  (external link)
IMAGE: http://farm6.static.flickr.com/5051/5515548360_df2301025e.jpg
IMAGE LINK: http://www.flickr.com …/60446252@N07/5​515548360/  (external link)
IMAGE: http://farm6.static.flickr.com/5255/5515548064_31aef8fe0a.jpg
IMAGE LINK: http://www.flickr.com …/60446252@N07/5​515548064/  (external link)
6D - T3i - 18-135 - 17-50 2.8 - 50 1.8 - 24-105L
Vimeo (external link)
Youtube (external link)
JMartel
Mar 10, 2011 13:09 |  #2
Ok the best way to learn is through critique so here goes:
1. You clipped the blacks. There's no detail at all below the car. The vignette does not work as it just makes everything too dark. The car is "leaning" to the right a bit, and the crop is too tight. It's slightly off center.
2. Better exposure than 1, but still no detail in the wheels or in the grass under the car. It's blown out on the horizontal surfaces. Crop is too close and it cuts off the front of the car in a weird place.
3. Car is leaning to the left as well as slightly turned to the left. Again, you have the issue of losing shadow detail and part of the hood being blown out. The roof is cut off, and the heavy vignette doesn't work again.
On all of them: Too much sharpening and the white balance is off.
Things you can do to change: Don't get so close to the car. Take photos that are level and straight and give the car room to breathe in the frame. Try different angles by holding the camera above your head or crouching down. Go lighter on the editing, especially the vignettes and sharpening. The hood/door lines should not be jagged. They should be one smooth line. The jaggedness is caused by over-sharpening. The light is pretty crappy in this as well. Early afternoon is probably the worst time of day to be taking photos as the camera does not have as large of a range that it can expose correctly as we do. Light around sunset/sunrise is always more camera friendly. You can deal with harsh sunlight by having flash or reflectors to fill in the shadows.
Just some things to consider and help you out next time you take photos.
Jeff
weavedesigns
Mar 10, 2011 13:30 |  #3
thanks alot!! I will work on those things
weavedesigns
Mar 10, 2011 13:45 |  #4
IMAGE: http://farm6.static.flickr.com/5175/5515711630_f8ce895215.jpg
IMAGE LINK: http://www.flickr.com …/60446252@N07/5​515711630/  (external link)
I think the crop helps this one more, I took the vignette off and WB it also tried to get some detail back in the hood, the shadows are gone though nothing I could do
JMartel
Mar 10, 2011 13:53 |  #5
weavedesigns wrote in post #11995742 (external link)
Right. The only way to fix that if you don't have a reflector or flashes is to use a tripod and take multiple exposures. Expose for the highlights and then expose for the shadows and combine the two.
Jeff
weavedesigns
Mar 10, 2011 14:07 |  #6
O ok thanks a lot
sigma ­ pi
Mar 10, 2011 14:30 |  #7
The edit looks a lot better but it is hard to shoot a white car in the mid day sun. Not much can be done.
Don't try to confuse me with the facts, my mind is already made up.
http://www.flickr.com …6850267535/in/p​hotostream (external link)
sansational
Reverse Psychologist
Mar 10, 2011 15:10 as a reply to  @ sigma pi's post |  #8
Can you edit the dark part in front of the car so it's a little bit lighter and shows the grass?
Andrew
Instagram (external link)
weavedesigns
Mar 10, 2011 15:41 |  #9
I cant, the picture isn t the best quality and it gets too noisy and blown out when I try to fix the exposure
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 10, 2011 22:18 |  #10
weavedesigns wrote in post #11996479 (external link)
Daytime shows in sunlight are tough. See the links in my Sig, and...
Sam_M
Mar 11, 2011 02:24 |  #11
Where in NH are you from?
Canon 50D | Nikon D850 D200
+ other assorted glass, plastic, and metal.
1,478 views & 0 likes for this thread, 6 members have posted to it.
2889 guests, 178 members online
