One from Friday night at the Avalon airshow.
I'm happy how this one came out let me know what you think
leigh
O_Lethal Member 56 posts Joined Jan 2011 More info | Mar 11, 2011 00:41 | #1 One from Friday night at the Avalon airshow. leigh
Desertraptor Cream of the Crop More info | Mar 11, 2011 02:09 | #2 Nicely done Peter
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Mar 11, 2011 02:17 | #3 You've given this a very stark and graphic look. Jay
Mar 11, 2011 02:21 | #4 There was quite a bit of noise before i messed around with it. The only problem i can see here is the sky and the nose. the motion blur has made it very soft or at least for me anyway.
xMClass Goldmember 2,203 posts Joined Jun 2008 Location: California More info | Mar 11, 2011 03:02 | #5 Very nice! -Mikey
PhotosGuy Cream of the Crop, R.I.P. More info | Mar 11, 2011 09:30 | #6 Nice one! O_Lethal wrote in post #11999781 There was quite a bit of noise before i messed around with it. The only problem i can see here is the sky and the nose. the motion blur has made it very soft or at least for me anyway. ill mess around with it later and see if i can reduce the noise more ![]() thanks Desertraptor ![]() If you don't have NR software, adding a little bit of gaussian blur just to the sky would help smooth out the noise. The easiest way I know to do that would be to select the F-18 first & then invert that selection before you do the gaussian blur. FrankC - 20D, RAW, Manual everything...
kitlens Goldmember 1,150 posts Likes: 1 Joined Mar 2008 Location: Durham, NC More info | Mar 11, 2011 20:24 | #7 |
Aerophile Senior Member 404 posts Likes: 3 Joined Oct 2010 Location: Central Texas More info | Mar 11, 2011 22:33 | #8 If you do a google search for "Neat Image" they have some pretty good noise reduction software for free. The free version only will do an area of 1024 x 1024 however. It also has a PS plug in. I use it occasionally. I haven't figured out a way yet to so selective noise reduction tho. Otherwise, I think it does a good job on it's own for free. Denton
| Latest registered member is icebergchick 1372 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
