Thread started 11 Mar 2011 (Friday) 17:07
lens hood w/ cpl ???
Titaniumpete
Mar 11, 2011 17:07 |  #1
I'm off to San diego next week, and in the hopes of capturing some of the amazing coastal images i've seen, I purchased my first circular polarizer filter. I will be taking both my canon 10-22mm and 24-70L. In the spirt of traveling light, my question is wether or, not I require both lens hoods with a cpl?
| 50D | Grip | Fuji X100 | Canon 24-70 f/2.8 L | 50mm f/1.4 | 10-22mm f/3.5-4.5 | 70-200mm f/2.8 IS mk1 | 430 EX II | Synology 211 NAS
"i think my ambition exceeds my ability"
Peter
DonSantos
Mar 11, 2011 17:10 |  #2
It's going to be hard to turn your polarizer with a hood
Current Gear: 5Dc | Canon 20-35mm | Canon 35mm 2.0 | 85mm 1.8 | 420EX
Previous Gear: 40d | 50d | Tokina 19-35mm | Sigma 30mm | Canon 50mm 1.4 | Canon 50mm 1.8 | 135L
Refresh ­ Image
Mar 11, 2011 17:10 |  #3
Titaniumpete wrote in post #12003508 (external link)
It is easy to use the hood and filter on 10-22 at the same time but the circular polarizer on a UWA is of very limited use. at least for skies.
On 24-70 you would have to take the hood off when rotating the filter.
SkipD
Joined Dec 2002
Mar 11, 2011 17:16 |  #4
Refresh Image wrote in post #12003527 (external link)
I don't have to take the hood off my 24-70. I merely do a quick zoom to the 24 mm position if I cannot reach the filter to rotate the ring. The hood is big enough, though, that I can usually reach the filter with relative ease.
Skip Douglas
gasrocks
Mar 11, 2011 17:42 |  #5
My Leica R 35/2 has a thumbwheel on the side of its hood for rotating the CP.
Titaniumpete
Mar 11, 2011 18:39 as a reply to  @ gasrocks's post |  #6
Thanks, but i guess my question is (pardon the ignorance) does the cpl negate the hood?
Or, am i still vulnerable to lens flare even with the filter on?
Thanks again,
Peter
SkipD
Joined Dec 2002
Mar 11, 2011 19:10 |  #7
Titaniumpete wrote in post #12004010 (external link)
No
Yes. Very much so, if you have bright light sources (even reflections of the sun, for example) in the scene that the camera is looking at.
Skip Douglas
noisejammer
Mar 11, 2011 22:13 |  #8
I've never used the hood for the 10-22 - it just seems to wide to achieve anything except when the lens is at 10mm (which I never used.)
You will get weird sky effects if you polarise light entering the 10-22. This is because skylight is polarised in different orientations so that the polariser has a variable effect. It's probably better to use a graduated neutral density filter if the sky is too bright. That said, unless the effect is extreme, you can usually pp it out.
24-70... don't have one but the hood's generally a good idea and can protect your lens from decelleration trauma on the ground.
Several cameras and more glass than I will admit to.
1,359 views & 0 likes for this thread, 6 members have posted to it.
1063 guests, 171 members online
