Thread started 11 Mar 2011 (Friday) 22:31
7D + PW Shutter Curtain Mishap???
OG4891
Joined Mar 2011
Mar 11, 2011 22:31 |  #1
I just purchased a 7D, got a feel for the settings, then popped on my pocketwizards (miniTT1, flexTT5) using a 430exII speedlight. I took a couple of shots, things were fine and dandy, then sporadically some shots would be dark from top down about midway, almost the same effect as when using a shutter speed faster than the max flash sync speed, hmm...
I have found 2 issues pertaining to this:
1) As I raise my ISO, it shows more prominently.
2) As I tilt my camera upward it shows more prominently, almost as if the curtain is falling.
I think there may be something screwy with the shutter, but I'm sure someone may be able to correct me if I'm wrong :D
*Note* This only happens when using the PWs. When the 430exII is mounted to the camera, everything works fine.
I'm thinking that I should return the camera and trade it for another, as I just bought it yesterday.
Has anyone ever heard of this happening?
www.photoboothmini.com (external link) | www.obigrant.com (external link)
Canon EOS 5D2 Gripped| Canon 24-105f4L | Canon 50 f/1.8 | Canon EOS T1i | Canon Speedlite 580EXII | Canon Speedlite 430EXII | Sunpak Auto 383 Super
Arstine
Mar 12, 2011 03:35 |  #2
Some radio triggers are a little slow, so you can't get max sync speed out of them. More than likely this is what you are running in to. Amusingly, I had the same experience with PWs but my cheapie Cactus V4s work perfectly at 250 with my 7D.
My camera says Canon and goes clickity clickity click.
My Flickr (external link)- (external link)Snapshots and fun pics go here.
http://www.photosbyjas​on.net (external link)
jra
Mar 12, 2011 03:53 |  #3
I doubt it's the camera causing the problem. Probably the pocket wizards are to blame I would guess. I'm guessing that as you raise your ISO or point the camera up (towards the sky I'm assuming), your shutter speed is increasing causing the problem to show up more frequently. Are you allowing the flash to completely recycle between shots?
Arstine
Mar 12, 2011 04:29 |  #4
Oh yeah, get it out of Av mode too. Sounds like that's what you're doing. Put it on M if you're going to be using off camera flash.
KhanhD
"I need a grip . . . on my life"
Mar 12, 2011 06:55 |  #5
Whats your shutter speed?
Khanh Duong | KHDPhoto.com (external link) | flickr (external link) | facebook (external link)
iPhone 5s + Instagram (external link)
OG4891
Joined Mar 2011
Mar 12, 2011 09:32 as a reply to  @ KhanhD's post |  #6
I guess I should have mentioned that I am using manual mode (including manual ISO setting), shutter speed set to various speeds: 1/30, 1/60, 1/80... I have tried it all. I have varied all sorts of combinations and it doesn't seem to change anything.
I've used my PWs with my t1i and never had this issue, still don't have this issue when I use it on the t1i now.
I'm sitting in my room, used low light, ample light, and no light: still to no avail. I've used it outside as well at late sunset, still to no avail.
Here's another weird part: when I crank the shutter speed up to 1/400 and faster, there are no issues!!! I don't get it.
KhanhD
Mar 12, 2011 09:37 |  #7
Is your flash on HSS?
OG4891
Joined Mar 2011
Mar 12, 2011 10:02 as a reply to  @ KhanhD's post |  #8
Nope.
OG4891
Joined Mar 2011
Mar 12, 2011 13:24 as a reply to  @ OG4891's post |  #9
Problem Solved!
In the PW Utility, under "misc", the camera was set to t1i, I changed it to auto and everything now works perfectly.
I'm not sure why it worked, but it did correct the problem.
Thanks for the input!
ilovemycamera
Mar 28, 2011 10:07 |  #10
glad that solved the problem... i've got a couple PW's that should be here friday and was planning on running them from my 7d
GEAR: -7D---Canon 24-70mm f/2.8L---Canon 70-[COLOR=black]200 f2.8L IS---Canon 50mm 1.2L---Canon 16-35mm f/2.8L---Speedlite 580 EX---Canon 100mm 2.8 macro---gitzo gt2942---RRS BH-55
WISHLIST: --- 5dmkiii --- Canon fisheye ---Canon 100-400L........ one day, my friends, one day!
AE-1
Gallery: 13 photos
Joined Aug 2011
Nov 12, 2011 21:08 |  #11
I have been using my pixel kings and 2 YN560's with my 60D for a couple months, I shot 1000+ pictures without a problem. Today I used 7D first time with the same set-up, one every ten pictures have the same problem. There is a dark (10-20% of the height) area at the top of the pictures.
If it was on the sides (vertical dark strip) I would say synchronization, but as far as I know curtains are moving side ways, not up and down, right ?
Never had any problems with 7D before, but I am using 7D mostly outdoors without flash. (using more than a year)
I am using Manuel mode, shutter speeds less than 1/200.
Any ideas ?
5DM3,7DM2,450D
500MM F4 IS, 16-35 F4 IS, 100 F2.8 L,70-200F2.8L IS II, 400 L F5.6 (SOLD and immediately regretted), 17-55 F2.8, 55-250 F4-5.6, 430 EX II, YN 460, Pixel Kings, umbrellas, stands, etc.
2,331 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is vinceisvisual
889 guests, 180 members online
