Thread started 12 Mar 2011 (Saturday) 08:07
Grip trick for extended shooting
GJim
Mar 12, 2011 08:07 |  #1
This works for the BG-E2 and BG-E7 (may or may not work for other models/clones).
If you are working with a gripped camera, opening the battery compartment (even if batteries are fully charged) shuts off the camera. There is a method to bypass this 'feature', but you need to know in advance that you are going to need this. This would be helpful for really long shooting sequences (night-time star trails, &c.) where you may very well need to change out the batteries but don't want to lose any of the camera settings, nor stop the long-exposure shot.
Before starting to shoot, open the battery compartment door. In the upper right-hand corner, just above the right-hand battery release, there is a small square hole. Using a small object (I used a straightened paper-clip) push on the left-hand side of the hole. You should hear a click as the switch returns to the left. Now, with the battery compartment door open, you should be able to power-up the camera.
Leave the battery compartment door open throughout your shooting sequence. As batteries become discharged, change out one - then the other - and continue shooting.
When you are finished, closing the battery compartment door will reset everything to normal.
G'Jim c):{- ... 2x 50D (Both Gripped), 2x 7D (Both Gripped), 2x 5D Mk II (One gripped), 1x 60D, assorted glass (10-800mm), sundry accoutrements.
The beginner clicks the shutter and says "Let's see what I got." ... The experienced photographer thinks "How can I capture what I see?"
My Photography: http://www.gjimphotogr​aphy.com (external link)
mjww
Mar 12, 2011 10:27 |  #2
Nice tip! Will be very usefull where one does not have readily available mains power.
Equipment list - According to the wife - "how many more lenses do you need? Yet another camera?"  ???
StealthFighter
Mar 13, 2011 03:41 |  #3
nice tip, too bad it doesn't work on grips with a tray.
1,188 views & 0 likes for this thread, 3 members have posted to it.
1549 guests, 135 members online
