Thread started 12 Mar 2011 (Saturday) 18:46
Somethings not right with this rented 70-200mm L f2.8 mk ll. HELP!
ProjectNineFive
Joined Jun 2010
Mar 12, 2011 18:46 |  #1
I just rented the 70-200mm L f2.8 Mk ll from lensrental.com. I received it a couple days ago but didn't have time play with it. I rented it for a pageant I was photographing today and this morning I go outside to microadjust. I was not able to get the lens adjusted and I tried all the way from -20 to +20 and none of the images were sharp. I was pretty heated seems how I was about to go photograph a pageant. My 24-70mm L 2.8 is ALOT sharper then this Mk ll lens. Of course it is the weekend and i'm unable to reach lensrental. After the pageant I went home and performed a focus test to see if it's front or back focusing but it was fine. I don't know what is wrong. I know when I micro adjusted my 50mm f1.4 and the 24-70mm lens you could see changes as you in each picture that has different micro adjustments until you find the sweet spot. With this rented lens none of the adjustments made it any better.
Project Nine Five Photography (external link)
My Facebook Fanpage<----ADD ME (external link)
DreDaze
Gallery: 49 photos
Mar 12, 2011 19:02 |  #2
you know people are going to want to see pics...
it seems like you're just looking for problems if you instantly micro-adjust lenses...but what do i know...i don't have that feature...but even if i did, i don't think i would go to micro adjust right away...
Andre or Dre
gear list
Instagram (external link)
focus.pocus
Mar 12, 2011 19:09 |  #3
agree with DreDaze... post some pics but seems like you are one of those guys that looks for problems where there aren't usually any...
I know, right? I'm just sayin'...
FreezeFramePhto
Mar 12, 2011 19:21 |  #4
I always seem to return my adjustment to 0. Let's see those pictures.
www.freezeframe.photo
dzaneh
Gallery: 6 photos
Mar 12, 2011 19:25 |  #5
I don't have micro-adjust I have 5 lenses all were sharp right outta the box! no problems...
stuff
ProjectNineFive
Joined Jun 2010
Mar 12, 2011 20:14 |  #6
I formated that cf card before i left for the pageant. Let me retake the pictures tomorrow morning and i'll upload to my website then post them tomorrow night. I'll also post a pic of the 24-70 to compare. I find it a little comical everyone asks why I micro adjust? Maybe because I want the best results from the lens and I didn't have time for trial & error to find out if it would needed adjusted.
reprazent
Mar 12, 2011 20:51 |  #7
Should have tested the lens upon arrival instead of shooting day?
Like it always amazes me when people say they upgraded their camera (2days before the wedding) or new fancy lenses but struggled to use it..
So did you bring the lens to shoot or not? Were you shooting in daylight or studio? kinda hard to believe that the focustest came out positively, but didn't look sharp dhen you tried MA. I wonder what kind of method was used when you were microadjusting?
gearlist | flickr (external link)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Mar 12, 2011 21:27 |  #8
ProjectNineFive wrote in post #12008990 (external link)
..I find it a little comical everyone asks why I micro adjust? Maybe because I want the best results from the lens and I didn't have time for trial & error to find out if it would needed adjusted.
Probably because it's comical to say that you didn't have time for "trial and error" which is exactly what you did by "trying everything between -20 and +20 ;)
On a less tongue in cheek note, though; without seeing the results you were unhappy with, exif info no one here's going to be able to make any suggestions or offer any help.
ProjectNineFive
Joined Jun 2010
Mar 12, 2011 21:51 |  #9
Oh I am sorry... I thought trial & error was actually doing maybe a couple photoshoots to figure it out. Instead I spent 15 minutes microadjusting. I guess everyones meaning of trial & error are different.
ProjectNineFive
Joined Jun 2010
Mar 12, 2011 22:03 |  #10
reprazent wrote in post #12009152 (external link)
I had the lens for 2 days but because of work I was unable to test it prior to the day I needed it. So it wasn't my intention to wait last minute. I was using it for a pageant. I had to bring the lens to the pageant because I don't have a telephoto lens. That was the whole point of renting the lens. Even though I wasn't happy with the micro adjusting I still had to use the lens.
When I did MA it was on a tripod with a timer during the daylight.
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 12, 2011 23:02 |  #11
If it were me, I would put the lens back to "ZERO" MA and shoot at f/5.6 or even f/8. That will minimize any focus errors. If you don't get sharp photos, the lens is bad not the MA.
If you can't get sharp photos at f/8 try it with the IS off. It's possible the lens was damaged in shipping. It could be just the IS is malfunctioning.
Micro Adjust doesn't make your lens take sharper photos. All it does it move the focus point slightly forward or backward. Even if you took a bunch of photos with the MA set from -20 to +20 and all points in between, the average photo will have some points somewhere in the frame that will be 100% in focus and they will have to be sharp.
I think MA is highly over-rated when it comes to zooms. Especially slow zooms or if you usually shoot a fast zoom stopped down. It's really only fast primes that can really benefit from MA, and only if your camera is precise enough to consistently hit the same focus, and only if the focus is not thrown off by changing the focus distance from near to far.
anthony11
Mar 13, 2011 05:50 |  #12
bannedPermanently
ProjectNineFive wrote in post #12009488 (external link)
You had to work for 48 hours straight???
FWIW I rented this model from LR in early November and the instance I received was awesome. UPS in Ft. Bragg, not so much.
5D2, 24-105L, 85mm f/1.8, MP960, HG21, crumbling G6+R72, Brownian toddler
skifurthur
Mar 13, 2011 08:48 |  #13
I've had quite a few dealings with Lensrentals.com and they have always overdelivered in the service area. If I had a problem out on the road and I sent them and e-mail at 3AM on a Sunday morning, I would awake with an answer in my inbox. If you look at their contact page they list their office hours and state e-mail and IM is the way to go when the office is closed.
www.amsaddler.com (external link)
Capturing the passion of performance
The "simple and sweet" equipment list: 40D, 7D, 300 f/2.8 IS L, 200mm f/2.0 IS L, 70-200 f/2.8 IS L MkII, 17-55 f/2.8 IS, Canon 1.4 extender
ProjectNineFive
Joined Jun 2010
Mar 13, 2011 12:44 |  #14
skifurthur wrote in post #12010891 (external link)
Thank you for the info. I tried calling them but they were already out for the weekend. I will email them.
I will be posting pictures tonight.
3,297 views & 0 likes for this thread, 10 members have posted to it and it is followed by 2 members.
966 guests, 184 members online
