Thread started 13 Mar 2011 (Sunday) 06:23
What batteries in your 580EXII
pxchoi
Mar 13, 2011 06:23 |  #1
As you can guess by the title, I am a 580EXII owner. I was shooting the other day and my flash had some what of a hiccup at a critical moment and I wonder if it was because of the batteries that I was using.
I admit, I was using cheap Kirkland brand batteries... I have a ton of them and we buy them in bulk for our daily needs.
Anyhow, I was shooting and it was working fine up until a crucial moment and it wasn't able to recycle fast enough to keep up with my camera. Batteries to blame? If so, then what should I use from now on?
Patrick Choi
Portfolio (external link) | Flickr (external link) | Facebook (external link)
EOS 7D | 580EX II | 10-22mm f3.5-f4.5 | 17-55mm f/2.8 IS |70-200mm f/2.8L IS II
For Sale: 17-55mm f/2.8 IS | 10-22mm f3.5-f4.5
kokakaste2
Mar 13, 2011 06:37 |  #2
From my personal experience, every set of batteries will start to recycle noticeably slower once they start to get empty. Get spare batteries, not because the first set will be empty but because at some point you will need fresh batteries to keep the recycle time quick. :)
Personally I use non-rechargeable batteries, get them in bulk use them in the ex580ii and when they start to recycle slow I put them in other things that use AA batteries (remotes etc.) However my use of ex580ii is very little, so set of batteries last for quite a while. :)
p.s. Also lower the flash output and increase ISO will help with how fast your batteries drain.
Oskar (Oscar) - stuff I use- Flickr (external link) - My Facebook page (external link) :)
drdiesel1
Gallery: 86 photos
Mar 13, 2011 06:45 as a reply to  @ kokakaste2's post |  #3
I use Eneloop ;)
I have an EX580II and an SB900 with 8 sets of 4 battery packs. Never had a problem with power or recycle times. The 5DMKII shooting RAW with an uncompressed 14 bit file isn't fast enough to cause problems, in that department :lol:
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
Roroco
Mar 13, 2011 06:49 |  #4
This has been discussed here before - several times. 80 percent of the people will move you toward Eneloops. They perform great and hold a charge when not in use.
I would be one of those people.
Roger
Gear List: 5D Mark III -- 50mm f/1.4 -- 85mm f1.8 -- 100mm f/2.8L IS Macro -- 17-40mm f/4L -- Tamron 24-70mm f/2.8 VC -- 70-200mm f/2.8L IS II -- 2.0X III TC
Lights -- Alien Bees B800 -- 580 EX II -- Yongnuo YN-560 II & YN-568EX -- Mother Nature -- RF 602s
pxchoi
Mar 13, 2011 06:51 |  #5
kokakaste2 wrote in post #12010611 (external link)
Thanks for the tip. At what point do you think the batteries would start to deplete and hinder recycling time. I'd like to say I was about 50 but definitely under 100 shots in when the hiccup occurred. I did put new batteries in and it seemed to be fine afterward, although shooting intensity slowed down to where recycling time didn't matter anymore.
Patrick Choi
pxchoi
Mar 13, 2011 06:52 |  #6
Roroco wrote in post #12010637 (external link)
Patrick Choi
Buttkicker
Joined Dec 2004
Mar 13, 2011 07:36 |  #7
Eneloop vote from me
5D3 - 1 Dmk2N - 40D - 24-70 F2.8 - 85mm 1.8 - 70-200mm F2.8IS - - 200mm F1.8 - Canon 400mm F5.6 - Canon 430ex111 - Yongnuo 6ooexRT - Nissin 866 - PW Flex/Mini - New Purchases pending :lol:
http://www.airteamimag​es.com/chris-procter_pid42.html (external link)
kokakaste2
Mar 13, 2011 08:04 |  #8
pxchoi wrote in post #12010643 (external link)
https://photography-on-the.net/forum/showthre​ad.php?t=677074
This thread might be interesting for you. :) I rarely use the 580exII now after I bought Elinchrom Quadra as most of the use for 580exII was off camera work. So I honestly cannot remember. :)
Hoppy1
Mar 13, 2011 09:04 |  #9
Eneloops, with a spare set of alkalines in the bag just in case.
Tip - the moment you detect the recyling getting a bit too long, raise the ISO and/or lower the f/number. One stop of either of those settings halves the flash output, dramatically cutting the recycle time and extending battery life.
5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
tanneu
Mar 13, 2011 09:05 |  #10
+1 eneloops
BrandonSi
Nevermind.. I'm silly.
Gallery: 62 photos
Joined Sep 2004
Mar 13, 2011 09:06 |  #11
Sunpak baby!! I've had them for 4 years and they still work great.. Though I do have eneloops in my other two YN560's, and IMO, eneloops are the better batteries.
[ www (external link)ยท flickr (external link)]
dmward
Gallery: 29 photos
Mar 13, 2011 10:31 |  #12
The batteries in the 580EX are in series. That boosts voltages. It also means that one weak cell in the 4 will degrade performance. When a flash starts to degrade recycle time before one would expect, it usually indicates a bad cell in the mix. Could also mean that several full power exposures have heated up the unit and thermal protection has kicked in.
Alkaline batteries start to drop voltage almost from the first shot fired. Eteloops, and other NiMH batteries have a stable voltage till late in their charge life. That also makes them better for flash units since voltage is related to recycle time.
To shorten recycle times the best approach is an external battery pack attached to the high voltage connection on the side of the flash.
drdiesel1
Gallery: 86 photos
Mar 13, 2011 15:57 |  #13
dmward wrote in post #12011186 (external link)
And use Eneloop's in your external pack ;)
pxchoi
Mar 13, 2011 16:01 |  #14
This is great info, very clear and concise. Thank you
Is this what I need?
http://www.adorama.com​/BYSEAA4WC.html (external link)
Patrick Choi
kjonnnn
Mar 13, 2011 16:03 |  #15
I use rechargeable Duracells. Never checked to see how long they last, but if I do an event they last thru it, a few hours and maybe 300 images.
5,774 views & 0 likes for this thread, 31 members have posted to it.
2699 guests, 138 members online
