Joe52 wrote in post #12011221
I shot a photo with my 60D, I used RAW+jpeg, the jpeg is 8mb, I then opened the RAW file in DPP and converted to jpeg with the same in camera settings, the jpeg from DPP is 12mb.
Why the 4mb difference in size, is it only because the camera is using more compression than DPP?
Yes, the difference is one of compression. The camera offers only three levels of compression because of "space" limitations, but DPP can use a more expansive set of algorithms and offer a wide range of choices. In fact, at one point in it's history (I'm afraid I don't remember which edition) DPP changed iis jpg compression engine, expanding the range by making the 10 end of the scale much less compressive. Level 7 or 8 does roughly the same compression as the camera's Fine setting.
As u0pt said, level 8 is plenty good for most uses, especially if it is not going to be resaved many times.
