Say I have 200 images at around 10mp per image and I need to resize all of them for Web use with each image no bigger than 1mp. Is there a way to batch resize them all at once using CS4?
SYS Cream of the Crop More info | Mar 13, 2011 16:14 | #1 Say I have 200 images at around 10mp per image and I need to resize all of them for Web use with each image no bigger than 1mp. Is there a way to batch resize them all at once using CS4?
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Mar 13, 2011 16:24 | #2 |
Mar 13, 2011 16:41 | #3 Damo77 wrote in post #12012680 Nah, just use File > Scripts > Image Processor. Under Image Processor, I check "Save as JPEG" and "Resize to Fit" (I assume) boxes. But what about the "Quality" box? It has at "5" as default. Also, do I click on the box, "Convert profile to sRGB"?
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Mar 13, 2011 16:45 | #4 Resize to fit the suitable pixel dimensions for your web images. Exactly what size that is you'll have to discern for yourself.
tonylong ...winded More info | Mar 13, 2011 16:50 | #5 I use a couple different dimensions, depending on how I'll be using the pics. For "serious" stuff I save to the POTN image max guidelines -- a max of 1024 pixels at the widest dimension. I use a Quality a bit above "half" (depending on your software). Tony
Mar 13, 2011 16:50 | #6 Damo77 wrote in post #12012792 Resize to fit the suitable pixel dimensions for your web images. Exactly what size that is you'll have to discern for yourself. The "Quality" box refers to the Jpeg quality, which, as you probably know, goes from 0-12. I think 8 or 9 is good for web, but test for yourself and see. Yes, definitely convert to sRGB for web. Great, thanks Damien!
PaulMR Member 63 posts Likes: 2 Joined Nov 2010 More info | Using Image Processor does not save the files as Save For Web. In other words the output file will still be fairly large due to still having all the metadata and embeded thumbnail.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Mar 13, 2011 18:17 | #8 |
tylerdan Member 31 posts Joined Dec 2008 More info | Mar 13, 2011 20:12 | #9 VSO Image Resizer, free downlaod from VSO, will batch resize allowing you to specify picture size and file size.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Mar 14, 2011 07:02 | #10 Paul MR wrote in post #12013034 Picture Processor and Bridge Processor fully support Save For Web. http://www.scriptsrus.talktalk.net/index.htm Looks nice, but gives "Sorry but this script needs CS3 or better" error using PSCS4… "I think the idea of art kills creativity" - Douglas Adams
PaulMR Member 63 posts Likes: 2 Joined Nov 2010 More info | Did you install the script in the correct folder?
benesotor Goldmember 1,827 posts Likes: 15 Joined Mar 2009 More info | Mar 14, 2011 14:57 | #12 If you're on a windows machine and want the simplest option...
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Mar 14, 2011 18:48 | #13 Paul MR wrote in post #12018374 Did you install the script in the correct folder? I must be going daft. "I think the idea of art kills creativity" - Douglas Adams
Get FastStone Image Viewer, very fast viewer including RAW, image resizer + batch.
| Latest registered member was a spammer, and banned as such! 2903 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
