Thread started 13 Mar 2011 (Sunday) 17:02
What are your techniques for stabilizing a zoom lens?
konfuzd1
Joined Mar 2011
Mar 13, 2011 17:02 |  #1
I just bought a 70-200 f4L last week, and I have to admit, whoever called it a "gateway drug" leading to an addiction to L lenses was absolutely correct! It puts my 28-135 kit lens to shame as far as sharpness, color, fringing, etc. The only drawback is that it is not the IS version. I'm looking for ideas on how to get better shots at slower shutter speeds. So far, I've figured out that if I grab my right arm with my left hand, the lens will rest perfectly on my left elbow and be much less shaky. I have it mounted on a 50D with a battery grip, so the extra weight helps also. The third factor I've noticed is that 6(ish) frames per second high speed continuous is almost as good as IS, but that one good shot of ten may not be the one I wanted. So that being said, I'm polling the audience for suggestions. Please let me know if you have a technique or contraption that can help reduce the shakiness of a non-stabilized zoom.
Gripped 50D; Rebel T2I; Rebel 35mm; EF 28-135mm f/3.5-5.6 IS USM; 50mm f/1.8 USM II; 70-200mm f/4.0L IS USM; 430EX II (and just for fun, Rokinon 500 f/6.3 mirror and 2x tube)
http://www.facebook.co​m/milliner.john?sk=pho​tos (external link)
crn3371
Mar 13, 2011 17:09 |  #2
Right hand holding camera. Left hand cradling lens with elbow tight against your body.
Saint728
Mar 13, 2011 17:12 |  #3
I use my left hand with thumb facing away from the camera under the lens cupping the bottom of the lens with my palm. I then rest my forearm/left elbow against my chest, sort of like a support bracket.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
kjonnnn
Mar 13, 2011 17:15 |  #4
Also try ...
http://www.photography​blog.com …nd-hold_a_telephoto_lens/ (external link)
Todd ­ Lambert
I don't like titles
Mar 13, 2011 17:23 |  #5
I put it on this thing called a tripod. It cures all woes!
;-)a
DreDaze
Gallery: 48 photos
Mar 13, 2011 17:36 |  #6
i've never seen that technique...it seems like it would be exhausting...
here's another video link:
http://www.youtube.com​/watch?v=EDsx3-FWfwk (external link)
i usually have my elbow into my body at about a 45degree angle...sometimes i do the method above, and use my shoulder
Andre or Dre
gear list
Instagram (external link)
tutwood
Gallery: 16 photos
Mar 13, 2011 17:45 as a reply to  @ DreDaze's post |  #7
£11 monopod from ebay
Shane ­ W
Mar 13, 2011 17:54 |  #8
Practice, practice, practice! I have the non IS f2.8 and it took some time to get comfortable and stable, but you will get it. Now, get back out there and shoot some more!
Shane W
70D | Sig 10-20 | EF-S 15-85 | EF 70-200 2.8L | Sig 150-500 | Viv 28 2.5 | Sig 30 | Tak 50 1.4 [COLOR=blue]| EF 100 2.8 Macro | 1.4x TC | Nodal Ninja 3 | Tripods | Some Flashes | My flickr  (external link)
Savas ­ K
Mar 13, 2011 19:43 as a reply to  @ Shane W's post |  #9
Soft touch works. The more you try to steady, the more rigid and un-steady goes the grip.
jeremytf
Mar 13, 2011 22:04 as a reply to  @ Savas K's post |  #10
If you pay attention, there are often opportunities to lean against a wall, rest your elbow on a railing, and otherwise take advantage of other structures. That can greatly help, in addition to being aware of your breathing and timing your shots accordingly.
Gear, Feedback
KVN ­ Photo
Joined Jun 2010
Mar 13, 2011 22:07 |  #11
Leaning against a solid object, or hold your breath before pushing full the shutter button
X-Pro1 + 18-55 f/2.8-4 OIS + 55-200 f/3.8-4.5 OIS
TS-E 24 f/3.5L II + XF 35 f/1.4 + XF 56 f/1.2
Sony RX100 II + G12
Travel the world!
Steve ­ of ­ Cornubia
Mar 13, 2011 22:08 as a reply to  @ jeremytf's post |  #12
This is what monopods are for. Apart from providing a steadying effect, they can be a big help fatigue-wise.
5D MK3, 7D, 70-200mm f/2.8L IS II, 24-70mm f/2.8L, 16-35mm f/2.8L, EF 1.4x TC MKIII, Nissin Di866 II, Nissin Di466
I hate being bipolar. It's great.
peregrineflier
Mar 14, 2011 01:28 |  #13
Use high shuuter speeds and don't look back. : )
Thanks, Tom the Peregrineflier ;) Lyle Washington
Canon 1D mk3, Canon 100-400 L, Canon 300mm f/4L IS
http://peregrineflier.​smugmug.com/ (external link)
MikeI
Mar 14, 2011 02:20 |  #14
Elbow into your chest and bump the ISO...the need to steady decreases with a faster shutter speed:)
Doubleshot Photography (external link) ~~~~~ [URL="[URL]http://phot​ography-on-the.net/forum/showpost​.php?p=3138451&postcou​nt=595"]My Gear ~~~~~ [URL="[URL]http://irel​and-photo.smugmug.com/"]Pe​rsonal Gallery
hennie
Gallery: 26 photos
Mar 14, 2011 06:05 |  #15
Use either a tripod, monopod or one of the many types of shoulder support that are mostly advertized for video shooting.
http://www.cameratown.​com …/DSLR_Cinematog​raphy3.cfm (external link)
My experience with a small sized shoulder support (fits in my pocket) is a gain in the same range as
what can be gained by IS (2->3 stops).
4,705 views & 0 likes for this thread
Latest registered member is Portlawslim
908 guests, 211 members online
