Hi,
Let me say off the bat that I am living in Hong Kong...arguably the world's most polluted city. All winter the sky has been a sheet of white. There's no definable shape in the sky...no cloud forms...just a blanket of white. Lower to the ground there is a white haze of smog. Some days thick as an English sea fog...other days not as bad. Even the green trees seem to have a film of white/ grey smog/ residue over them. To say that colours here in Hong Kong are dull (discounting neon at night) is a bit of an understatement. There just isn't a rich deep blue sky/ lovely gradient blue sky as a backdrop...there's no beautiful white clouds off-setting that. Once in a blue moon this winter we have got rich blue skies. 98% of the time it is just terrible.
Having said that, let me ask a couple of questions.
My time in HK is coming to an end, and since I came here 4 years ago I always said that I will spend time on the street capturing the people and the local scenes. I've always wanted to document the local faces, the local life....so my first question is about metering.
I'm new to dslr
I use a 60D and a 35mm f2 or a 50mm 1.8 II for going around the street. I have found that using spot metering or a center based metering style (or any of the metering options for the 60D)...I've found that the results on the street are varied...a lot of shots seem to be overexposed...harsh whites...and I'm sure that's a result of the sky itself...which is an unforgiving white haze of smog. So, anyway...I'm looking for tips people may be able to offer for achieving a balance of dark and light when on the street in these hazy, white sky circumstances.
I guess I have been using Av mode, somewhere like f11 and focus on Auto...usually triggering off a face...as I want to capture people. Is there something that I should do/ can do prior to starting where I can more or less determine a range of settings...like white balance manually to the area (but that's problematic...or is it...due to the variety of lighting on a street)...should I manually set focus to achieve good focus for everything 4 feet in front of me? What metering mode? Spot? Evaluative?
I feel as if my shots are washed out (shooting in RAW)...and I keep thinking it is the environment...the streets themselves are drab, grey, colourless places (not all the time of course)....and the sky...the damn sky...everytime the sky is in shot it's just a disgusting blare of white haze.
I feel like the RAW images are kind of devoid of colour...I guess I am used to seeing the amped up jpegs of a Lumix P&S...I can of course manipulate the image in software...but I thought RAW would give me a rich representation anyway....and yeah...this is a problem owing to what I described about HK and the depressing white haze which seems to wash all colour out of everything. Even to the naked eye it's pretty drab...so I suppose the RAW shots aren't really lying.
So...I suppose that's about it...as a novice, sure I've done some reading...but thought I would start a thread to make my case a bit more specific and see what advice I could get.
I will post examples later...
thanks
PS...it kind of seems that the metering is so sensitive to where you aim. You meter a slightly dark area on a face or a shirt...and bang...it'll attempt to lighten these...at the expense of other areas already light...then these areas will be overexposed. You meter on a light place/ spot...and then suddenly it'll attempt to darken...there seems to be no easy way to balance dark and light given the metering modes and the quick action/ reflexive action of taking spur of the moment street type shots. This is my problem. Given what I have read...that's just the way it is.
