Thread started 14 Mar 2011 (Monday) 23:55
Which is the best scanner to scan medium fomat film?
oharing
Mar 14, 2011 23:55 |  #1
I am looking for the best scanner for scanning medium format film. What do you use?
Miami Wedding Photographers (external link)
ssim
Joined Apr 2003
Mar 15, 2011 01:31 |  #2
I use the Nikon 9000ED (external link) for scanning all of my medium format (6x7) films and transparencies. This isn't manufactured by Nikon anymore but there are lots to be found online. I have no complaints about it.
clipper_from_oz
Gallery: 29 photos
Mar 16, 2011 08:59 as a reply to  @ ssim's post |  #3
Have a look at the epson v750. Although its a flatbed scanner I use it to scan 6x17 large format transperancies for my commercial Panorama workand Its that good that when I show people comparisons of scans between an imacon scanner costing 10 times and my v750 they cannot tell the difference!!!.
Rgds
Clipper
R5, 5DSR, Fotoman 6x17cm Large Format Panorama Camera,Mamiya Universal 6x9
Canon EF 16-35mm f4 L, 17mm TSE f4 L,50mm f1.4, 24-70 f2.8 L, 70-200mm F4 L, 85mm f1.8, 100-400mm II L,
EF 400mm f2.8 IS II L, RF 600mm f4 IS L
Rodenstock, Sinar& Nikkor LF lens for Pano (75,95,150+210mm)
mcluckie
I play with fire, run with scissors and skate on thin ice all at once!
Gallery: 109 photos
Mar 16, 2011 10:16 |  #4
What you're looking for is dMax. The range that the scanner will capture. Res's are all up there but and medium format is a decent size. Remember optical res is all that matters. The smaller number given is the optical res, I believe vertical (??) and the other is interpolated from 1/2 that.
I have a few year old Epson 4990 with 3.9 dMax and losts of res. It's amazing. There are surely newer ones out there -- in fact Epson has one that scans 2 lasers at the same time, different angles. But again dMAX is Key. Some of the dust removal stuff is wonderful.
multidisciplinary visual guy, professor of visual art, irresponsible and salty.
Leicas, Canons, Hasselblads
all and historic dingus
krb
Mar 16, 2011 10:30 |  #5
The best is probably one of the Imacon units. I saw one used in good condition for $7500 recently on another forum, if you're interested.
Next step down would be the Nikon unit mentioned above, which can usually be found used for $2500-3000.
And the next step down from there would be the Epson 750. If you go for one of these then I strongly recommend getting a film holder with glass from betterimaging.com
You should also check out http://www.dpug.org/ (external link) and the 2 "analog" forums on getdpi.org for more info.
-- Ken
Gear list
1,345 views & 0 likes for this thread, 5 members have posted to it.
2903 guests, 168 members online
