pknight wrote in post #12036711
If I understand what you are saying, that would involve going into the menus and changing the AEB spacing between bracket sets.
Actually, I find that the easier way is to take 2 brackets but change the starting exposure settings of each one so that they overlap. This also gives greater control over the amount of sepration in the bracketed shots.
IOW:
- figure out the settings you want for your center exposure. Let's say that 1/125 is the shutter value for our middle shot.
- select the amount of bracketing you want, we'll use 2 stops.
- adjust the settings so that you are underexposing by the amount of separation you want. In this case, we want 2 stops so you'd be setting the shutter to 1/500.
- fire the bracket, which will give shots at 1/500, 1/2000 and 1/125.
- adjust the settings so that you are overexposing by the same amount. In this example we want 2 stops which would be 1/30.
- fire the bracket and you'll get shots at 1/30, 1/125 and 1/8.
- throw out one of the shots with duplicate exposure and you'll have 5 bracketed shots. In this case you will have: 1/8, 1/30, 1/125, 1/500 and 1/2000.
If you want to stick with 1 stop between each frame, you can also do it by:
- set the AEB to 2 stops
- select the correct exposure
- fire the bracket
- reduce the exposure settings by 1 stop
- fire another bracket
- throw away the underexposed shot from the second bracket.
If you start with 1/125 as your shutter speed, the first bracket from this would give you 1/125, 1/500, 1/30. Then you'd set the shutter to 1/250 and the second bracket would give you 1/250, 1/60 and 1/1000. Throw away the 1/1000 shot and you are left with 1/30, 1/60, 1/125, 1/250 and 1/500.
