Does it still apply if you're doing OCF with triggers? If yes, then how do you, for instance, use a wide aperture for nice bokeh if the ambient light is too bright?
Mar 16, 2011 08:58 | #1 Does it still apply if you're doing OCF with triggers? If yes, then how do you, for instance, use a wide aperture for nice bokeh if the ambient light is too bright? Michelle Brooks Photography
BrandonSi Nevermind.. I'm silly. More info | Mar 16, 2011 09:05 | #2 What is the 1/250 rule? Your shutter speed when using flash is limited to your sync-speed, unless using HSS.
mnaz Member 186 posts Joined Jan 2008 Location: Bay Village, OH More info | Mar 16, 2011 09:07 | #3 That's usually the highest it can be. If your ambient is too bright for the aperture you want to use then you would probably have to use an ND filter to knock the light down some.
rockfordhx Senior Member 696 posts Likes: 1 Joined Jul 2007 Location: US More info | Mar 16, 2011 09:14 | #4 yep, both posters above are correct.
Mar 16, 2011 09:16 | #5 I'll have to study up on HSS. ONly have one ND filter that I doubt is strong enough to do much. Thanks! Michelle Brooks Photography
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | Mar 16, 2011 09:37 | #6 FYI, you are going to need eTTL compatible triggers and receivers to make HSS work off camera.
fredroj Member 66 posts Joined Jan 2005 Location: Pueblo, CO More info | Mar 16, 2011 10:05 | #8 that rule can be broken.....just shoot at a high sync then crop later....
Mar 16, 2011 10:50 | #9 ShotByTom wrote in post #12030760 You have everything you need, put one 580 on-board and use the other off-camera, have both set to HSS. Thanks, Tom, I;'m trying to find some info (wasting time here at my "other" job) on HSS so I can understand how it works. Michelle Brooks Photography
Dekun Senior Member 315 posts Joined Jun 2010 More info | Mar 17, 2011 02:32 | #10 Michelle Brooks Photography wrote in post #12031144 Thanks, Tom, I;'m trying to find some info (wasting time here at my "other" job) on HSS so I can understand how it works. Anything you need to you about canon flash, well, terminology and technology wise. 6D | 30D | Powershot S5 | 10-22 f/3.5-4.5 | Tamron 17-50 non-VC | 24-105 f/4L IS | 50 f/1.8 | 85 f/1.8 | 100 f/2.8L Macro IS | 580EX II | Cactus V5
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Mar 17, 2011 06:41 | #11 Michelle Brooks Photography wrote in post #12030504 Does it still apply if you're doing OCF with triggers? If yes, then how do you, for instance, use a wide aperture for nice bokeh if the ambient light is too bright? Do you understand the reason for a "maximum sync speed" when using flash lighting? Skip Douglas
maxwell1295 Senior Member 789 posts Likes: 2 Joined Jul 2009 Location: Long Island, NY More info | Mar 17, 2011 06:59 | #12 fredroj wrote in post #12030869 that rule can be broken.....just shoot at a high sync then crop later.... This. Canon EOS 1n|Canon 40mm Pancake|Canon 50mm/1.8
ckalephoto Goldmember 1,006 posts Likes: 1 Joined Jan 2008 Location: Charlotte, NC More info | Mar 17, 2011 08:30 | #13 Michelle, Going off of your gear list, Tom is correct if you do not want to spend any money. Using one flash is no different then when you had your ST-E2 though, and has limitations in bright sun light. If you can drop some coin, get some radio poppers or PW Flex's. Chris
[Hyuni] Goldmember 1,186 posts Likes: 15 Joined Dec 2008 Location: CHiCAGO More info | Mar 17, 2011 08:54 | #14 The only reason people shoot @ 1/250 with flash is because they want to knock out most or all ambient light. If you're shooting outdoors where there's too much ambient light, then it won't matter. Mike Jacob Vintage 1/400 - f/2.0 - ISO800 w/ reflector (silver) camera right There's a few more of him where all I did was use light from a window and the reflector 6D Rokinon 14 f/2.8 l EF 35 ƒ1.4L l EF 135 ƒ2.0L l EF 70-200 ƒ2.8L IS II l YN460 l 580EX II l Flick'd
FlashZebra This space available 4,427 posts Joined Mar 2006 Location: Northern Kentucky More info | Mar 17, 2011 09:06 | #15 My frequent contribution to the understanding of the X-sync shutter speed limit.
| Latest registered member was a spammer, and banned as such! 2839 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
