Thread started 16 Mar 2011 (Wednesday) 10:14
The Simplest 7d to 5dII comparison question
Kit ­ Cloudkicker
Mar 16, 2011 10:14 |  #1
Hey guys,
I'm not going to get into specs and quality and performance and blah blah blah. I just have a simple problem and need a simple answer.
I'm in the process of buying yet another camera bag because my most recent one was purchased prior to my new gripped 5dII (Burton Resolution Pack). It was way too much room for my gripped xsi, but the 5dII is significantly larger as you all know. The problem i have with my current bag is that the camera pouch section isnt deep enough to house the 5dII gripped.
I am currently looking into a new bag (the Burton F-Stop) and have been unable to find anyone using this with a gripped 5dII. I did find someone using it with a gripped 7D so here is my question.
What is the height of the 7D gripped?
Also if anyone can help me out and just post up the height of their gripped 5dII i would appreciate it. I can measure when I get home, But i'd like to have the bag ordered by this morning while i'm at work
Thanks in advance guys.
Canon 6D, 24-105 f/4, 50 f/1.4
krb
Mar 16, 2011 10:17 |  #2
These two cameras are virtually identical in size. The style of quick detach plate or L plate that you attach will probably make a bigger difference.
-- Ken
Gear list
Kit ­ Cloudkicker
Mar 16, 2011 10:19 |  #3
the only spec I'm fully concerned with right now is if you were to rest the gripped camera on itself and measure from the surface its resting on to the top of the hotshoe, what that number is. I'm not sure if the grips are sized differently etc.. i dont care about width or anything like that, just need to know if the bag im looking into will be deep enough to fit it with some room.
big_g
Gallery: 418 photos
Mar 16, 2011 15:36 as a reply to  @ Kit Cloudkicker's post |  #4
I haven't got both cameras with me as I am away from home tonight but from memory they are almost identical. If there is any difference it really is just a few millimetres. Will a couple of mm really make a difference?
Very lucky to have a lot of nice toys :)
Flickr Site (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 16, 2011 16:13 |  #5
The 5D2 is 4mm taller (4.5" vs 4.3")
http://a.img-dpreview.com …ages/allroundvi​ew-001.jpg (external link)
Kit ­ Cloudkicker
Mar 16, 2011 16:31 |  #6
big_g wrote in post #12032885 (external link)
thats what i was asking, if they were identical, i didnt know... im just trying to find a new bag that will fit a gripped 5dii but the only review i found on it that someone had was a gripped 7d so i wanted to make sure the gripped 5dii wasnt significantly larger..
i know they are roughly the same size stock.. i'm asking for the GRIPPED... the grips change the size...
i found my answer through other channels though... thanks anyways, i guess this question was harder than i thought...
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 16, 2011 16:32 |  #7
So was a gripped 7D 4mm smaller than the 5D2 gripped? Or did the grip even up the overall height?
The assumption is that they are very close in size, and the Canon grips are very close in size as well (since they use the same battery and all), so if you know the size of your 5D that is gripped, the 7D will be very close to that, by 1/2 inch or so maybe.
I am betting it is around 157mm, so around 6.2"?
krb
Mar 16, 2011 16:37 |  #8
Kit Cloudkicker wrote in post #12033192 (external link)
Since you found your answer, why not post it?
-- Ken
Gear list
Kit ­ Cloudkicker
Mar 17, 2011 10:13 |  #9
krb wrote in post #12033228 (external link)
Big_g posted it up as well, I had a friend do a quick back to back comparison when he got home and they are just about the same size. The 5dII is slightly taller but as pointed out its a negligible difference.
Thanks for your help guys i appreciate it
krb
Mar 17, 2011 10:56 |  #10
Kit Cloudkicker wrote in post #12037510 (external link)
So you had the correct answer within 3 minutes but felt the need to post "this question was harder than i thought..."
:rolleyes:
-- Ken
Gear list
Kit ­ Cloudkicker
Mar 17, 2011 14:12 |  #11
krb wrote in post #12037766 (external link)
:rolleyes:
that was more in response to someone posting up product specs of each body... i tried to do a little research before posting up... anyone can look up specs of the bodies, i couldnt find specs on the grips... so yes.. apparently it was harder than i thought because people didn't read my question and just gave me stock specs...
not trying to be rude, i just thought i explained myself in the original question fairly clearly...
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 17, 2011 15:28 |  #12
Kit Cloudkicker wrote in post #12038971 (external link)
But I think the point is, again...
1) You have a gripped 5D2
2) The size specs of the body alone for both the 5D2 and 7D were given, showing that the 5D2 is 4mm taller
3) The grips are nearly identical
Therefore, logically, you would expect that the 7D with grip is either a tad smaller than your 5D2 gripped or the same exact size.
In any case, you now have your answer, so did you end up with a new bag? I am looking at the Tamrac series that hold 2 DSLRs, not sure which I like most though. :(
Kit ­ Cloudkicker
Mar 19, 2011 13:20 |  #13
TeamSpeed wrote in post #12039456 (external link)
The I wasn't sure how identical the grips were in height, that's why i was asking... no worries..
i just sold my crumpler bag and i'm trying to decide which bag to go with... im thinking maybe one of the kata bags but im nervous to make the jump to another bag without test fitting my gear in person first...
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 19, 2011 19:36 |  #14
I have 2 Kata bags today, which are you looking for? I have the H16 and the R102. I actually need to sell the H16, I think, and move to a bag that can hold 2 DSLRs, I am thinking about one of the Tamracs. Right now I am using the Canon DG-200 and am able to stuff the 1D4 + lens, the 5D2 + lens, a 70-200 2.8 IS, and a 580 EXII int the main compartment.
Kit ­ Cloudkicker
Mar 20, 2011 10:50 |  #15
I was thinking either the Kata Bug 205 or the BumbleeBee... I like the inside design of the Kata Bags but i really don't like the strap systems. They don't seem like they would be very comfortable and don't really appeal to me aesthetically
3,480 views & 0 likes for this thread, 7 members have posted to it.
896 guests, 119 members online
