Thread started 17 Mar 2011 (Thursday) 14:49
Does 7D Handle Raw Differently?
sobad
Mar 17, 2011 14:49 |  #1
I've been making and using templates in CS4 for a few years and just upgraded to CS5 and a Canon 7D. Now when I open RAW files, make any adjustments and place them in the templates the colors look off on the inserted photos but the templates look the same.. I've checked the color settings and everything looks the same. What am I missing? By the way jpgs don't do this only RAW.
Canon 1DMKIIN, 7D, 40D, 70-200 f/2.8L IS, 17-40 f4L, 28-135mm IS, 85mm 1.8, 35mm 2.0, 50mm 1.8, , 18-55mm kit, 430EX II, 580EX II (2), AB800 x 2
Tamron 17-50 f/2.8
woos
Mar 17, 2011 15:37 |  #2
Have you isolated the 7d? IE, I bet other camera's raw files will behave the same. I'd test that first.
amanathia.zenfolio.com
sobad
Mar 17, 2011 16:44 |  #3
Looks like its the color profile settings. I'm setting everything to sRGB to see if i can get it to play nice. I just did a bunch of T&I pictures the other day with CS4 and as usual all i had to do was open my RAW files, make whatever changes i wanted then drag the jpg over to the template.
Tamron 17-50 f/2.8
tonylong
...winded
Gallery: 60 photos
Mar 17, 2011 17:56 |  #4
I'm not sure exactly what you are describing -- are these templates for printing, or what? What is "T&I"?
And, what is the process you are doing -- open the Raw files in ACR and then into PS converted to the sRGB color space, saving as jpegs and then doing something with the jpegs?
Tony
sobad
Mar 17, 2011 20:01 |  #5
The templates are for printing, T&I = Team and individual. Normally, I open the RAW files in Bridge then move to PS and insert it to the template, add text and save as a jpg. I think i have the problem solved. It appears that by default Bridge was opening the Raw files and using Adobe RGB, the templates are set up as sRGB.
Tamron 17-50 f/2.8
tonylong
...winded
Gallery: 60 photos
Mar 17, 2011 21:41 |  #6
Ah, there you go, the old color space bugaboo! Good you caught that!
Tony
René ­ Damkot
Mar 18, 2011 05:17 |  #7
If you create a new document, PS will use the "default" color space. sRGB in your case by the sound of it.
If you didn't tick the "mismatch" box, PS will convert the AdobeRGB raw to sRGB before placing it. If you did tick the box, PS will ask you what to do.
Colors should *not* change.
If they do, your color settings are wrong.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,048 views & 0 likes for this thread
Latest registered member is Rooster7
936 guests, 303 members online
