Thread started 17 Mar 2011 (Thursday) 17:59
Formal portrait
csondagar
Joined Mar 2004
Mar 17, 2011 17:59 |  #1
bannedPermanently
This is the first time I have taken a formal portrait...
IMAGE: http://www.sondagar.com/albums/my_photos_to_upload/normal_20110306-005.jpg
My Website (external link) | flickr (external link) | 500px (external link) | 7D, EF 50mm f/1.8, EF 24-105mm f/4L IS USM, EF 75-300mm f/4-5.6 III USM | Speedlite 430EX | Reflector Disk 5-in-1 110cm
JakAHearts
Mar 17, 2011 18:47 |  #2
The background looks good with the light around her to get separation but the light on her looks too flat to me. Did you use the pop up flash to light her?
Shane
ootsk
Joined Jan 2002
Mar 17, 2011 18:51 |  #3
You certainly got some things right with this one.
Great smile, I like the head tilt. Exposure looks fine.
Things I'd do differently?
I'd crop out the negative space behind her...if you want to use neg space, make it on the other side.
I'd have her tilt the other direction, so her part is on top....it just allows the hair to flow a bit more natural looking. I'd also get higher, and shoot slightly down on her. First off, it's thinning for the neck, and it makes the eyes look a bit better when she's looking up. Flash looks to be on-camera. If that's all you've got, fine. Try to get it off, or better yet, use a window for light and ditch the flash.
kuraz
Mar 17, 2011 19:05 |  #4
Hi there. Nice first attempt. I honestly can't see nothing really wrong with this photo. Do you have any in portrait orientation?
The above makes a good point about shooting slightly higher for her
Gear
csondagar
Joined Mar 2004
Mar 17, 2011 21:28 |  #5
bannedPermanently
JakAHearts wrote in post #12040422 (external link)
No. I used my 430EX off the camera - placed on my right side about 6ft away from the subject. I don't quite understand how to make light on her not look flat. Would appreciate some clarification/tips on this. Thanks.
ootsk wrote in post #12040435 (external link)
I'll try out your suggestions on her tilting on her right and shoot slight from top. I have a 430EX and 7D pop-up flash. I used 430EX off the camera. Thanks for the tips.
kuraz wrote in post #12040511 (external link)
No. I donot have portrait shot. Will try it out next time. Thanks.
JakAHearts
Mar 18, 2011 06:55 |  #6
I think the lighting looks flat because the popup flash also added to the exposure of the picture. See the little catch light dead center in her pupil? Thats a good indicator that the popup flash lit her. Im pretty sure you can disable that so that only the preflash sets off the off camera 430. I dont have a 7D so I cant help you with that but hopefull someone will chime in here and if not, its in your manual. :D Hope that helps.
Shane
bbvdm
Mar 18, 2011 07:01 |  #7
I don't think the exposure is correct. It looks slightly underexposed. One critique was the lighting was "flat". I agree with that. The exposure on both sides of the face look identical and there are no soft shadows to define the face. Ideally, you would want some soft shadows on one side of the face to create definition. Also, if the light was to your right, I'm a little confused about the catchlight in the center of her eye. Did you also use your pop up flash? Recommendation: Move the light further to her left and higher with possible reflector on her right to fill in dark shadows. Good start.
Canon 5D MkII gripped, Canon 7D gripped, Canon 40D gripped, Canon XTI (IR) gripped, Canon 17-55 2.8 IS, Canon 60 Macro 2.8, Canon 70-200L 2.8 IS , Canon 24-105 4.0, Tokina 11-16 2.8, Canon 50mm 1.8, Sekonic L-358, Canon Speedlite 580-EX II, (2)430-EX, Pocket Wizards, lots of other stuff that seems to keep growing...:lol:
csondagar
Joined Mar 2004
Mar 18, 2011 10:47 |  #8
bannedPermanently
JakAHearts wrote in post #12042864 (external link)
Thanks. I checked the exif info on my raw and it does not show whether both flashes fired or only one. Regardless, my popup flash may have fired. I will try it out without (7D manual shows how to set master/slave flash arrangements). Cheers!
csondagar
Joined Mar 2004
Mar 18, 2011 10:48 |  #9
bannedPermanently
bbvdm wrote in post #12042878 (external link)
Thanks for the recommendation. Will try it out and post new photo soon.
csondagar
Joined Mar 2004
Mar 20, 2011 13:21 |  #10
bannedPermanently
So, I attempted formal portraits again with suggestions made above. I have chosen two portraits that I think captures the suggestions (and ones I like).
What do you think of these?
#1:
IMAGE: http://www.sondagar.com/albums/my_photos_to_upload/normal_20110318-024.jpg
#2:
IMAGE: http://www.sondagar.com/albums/my_photos_to_upload/normal_20110318-019.jpg
CBJammin103@gmail.com
Mar 20, 2011 16:32 as a reply to  @ csondagar's post |  #11
Wow, massively better! The only thing that catches my eye at first is that I'd like to see more DoF separation between her and the background... that is, a more blurred out background. You could probably hit it in post production at this point.
Great improvement there! ;)
csondagar
Joined Mar 2004
Mar 21, 2011 23:04 |  #12
bannedPermanently
CBJammin103@gmail.com wrote in post #12057488 (external link)
Thanks. I blurred the background and have update the photos.
Hope I hear from others as well.
csondagar
Joined Mar 2004
Mar 26, 2011 14:12 |  #13
bannedPermanently
I'd like to hear from JakAHearts, ootsk, kuraz, and bbvdm on what they think of the latest photos. I took your advice, and want to see if you think I've hit the mark.
Would also like to hear from other pros out there.
ootsk
Joined Jan 2002
Mar 26, 2011 21:39 |  #14
I took a shot at cropping it more towards a formal portrait style. I prefer an 8x10, either landscape or portrait.
I also tilted it as a "masculine" tilt. Look up the different types of tilt...but generally masculine can be done by either sex, but feminine can usually only be done by a female. I left the black line so you can see how much I tilted and cropped it. I would have shot this larger, and included more of her blouse, but I only had to work with what you gave me.
Anyways, this is my view of how to improve this photo.
I DO think it's a major improvement over your first one, so great job on that.
Keep shooting!
csondagar
Joined Mar 2004
Mar 27, 2011 11:31 |  #15
bannedPermanently
ootsk wrote in post #12099733 (external link)
Keep shooting!
Ootsk, this crop and tilt is compelling. Thanks.
4,235 views & 0 likes for this thread, 7 members have posted to it.
Formal portrait
2934 guests, 137 members online
