FORUMS Photography Talk by Genre Weddings & Other Family Events Talk
Thread started 17 Mar 2011 (Thursday) 18:27
Hypothetical Situation (For you)
*Jayrou
Mar 17, 2011 18:27 |  #1
You're in a Church with your 5D Mark ii and 70-200 F/2,8 IS ii,you're using centre point focus and AI SERVO, F/2.8
The brides walking down the isle and you want to make sure her face is in focus but also her full body in shot and the background blurred.
is it possible? if so how?
End of hypothetical situation.
Now this happened to me, I was just a guest at the wedding, but those settings where what i had, and to achieve what i wanted, the bride got chopped in half, by me focussing on her face with the centre point.
I'm reluctant to use outer points because they just seem to hunt in AI Servo.
Would love some insight on best practice in this situation.
James
James
Flickr  (external link)
Website (external link)
Red ­ Tie ­ Photography
Mar 17, 2011 18:40 |  #2
You could always shoot very wide and crop. It would be interesting to see what others would say.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
*Jayrou
Mar 17, 2011 18:57 |  #3
Red Tie Photography wrote in post #12040389 (external link)
Wow Bryan, Love your portfolio!
really nice stuff there...Brilliant
So, has this situation appeared in any form to you?
what's your best practice in that situation.
many thanks for responding.
James
jcolman
Gallery: 17 photos
Mar 17, 2011 19:15 |  #4
I use this exact combo and center the focus somewhere on her waist, assuming that I can find a contrasty spot.
While this isn't a church shot, I shot it at f/2.8 with center spot focusing
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i182.photobucke​t.com …20esession/megh​an-126.jpg (external link)
However I rarely use the 70-200 for subject moving shots in a church. I like to get a bit closer and use my 35L or 16-35 but I use the same technique
http://i182.photobucke​t.com …ee%20wedding/th​ad-174.jpg (external link)
www.jimcolmanphotograp​hy.com (external link)
Mar 17, 2011 19:18 |  #5
*Jayrou wrote in post #12040459 (external link)
Thank you very much. I really do appreciate your kind words.
jcolman wrote in post #12040571 (external link)
I tried this when I photographed a pageant last week, but found even shooting at f4 wasnt getting focus on the face. I switched to one of the upper focus points (one of the far right ones, switched to vertical) and had much better success. I just wanted to make sure to take a lot of photos and refocus to hopefully get one sharp enough.
Bryan
*Jayrou
Mar 17, 2011 19:38 |  #6
Jim fantastic shots, love the first one, its got a '135mm' look to it, beautiful colour to it, great capture.
It seems I'm not alone with this then?... I suppose focal length plays massively into this? and depending on orientation of the middle body to head is a deciding factor?
I mean you have a slim lady, her mid drift is likely to be on the same focal plane as her face, while the larger lady would be slightly harder to get both in focus without using a wider aperture?
Am I thinking to deeply into it?
James
*Jayrou
Mar 17, 2011 19:42 |  #7
Red Tie Photography wrote in post #12040586 (external link)
well deserved credit!
James
highway0691
Mar 17, 2011 20:05 |  #8
You are really trying to do a lot here, in a low-light church this could be a challenge without using a flash.
There is nothing worse than a sharp image of a fuzzy concept. Ansell Adams
*Jayrou
Mar 17, 2011 20:21 |  #9
highway0691 wrote in post #12040867 (external link)
I appreciate what you're saying , but If I can get her face in focus, surely the rest should follow?
its just the awkwardness of AI focus, full body and centre point.
I need AI Servo for movement, I need centre point for accuracy , I just need a bigger viewfinder to fit her in.
Is this where I need a 1D instead of a 5D, are 1D outer focus points more sensitive?
How hard for Canon would it be to make outer points as accurate as the centre point on a 5D?... surely this has to be some sort of software related arthrogram?
When you spend £1500 on a body, you would expect a little more, IQ blows me away at times, but focussing has got to be an issue with it.
James
highway0691
Mar 17, 2011 20:59 |  #10
I'd forget about the 1D, a 5D Mk2 is more than sufficient in this situation. Also on the issue of focus I use one shot mode all day. Walking dow the isle happens fairly fast and that depends on how long the Isle is, but in my experience it can be all over in less than a minute. There's so much more to consider than the shot you're after, simply it might just not happen due to variables out of your control.
This shot below using a fill-flash,iso 500, 2.8, 1/200 sec on a 24-70L One of 17 shots I took in that minute in a fairly well light church.
siddr20
Mar 17, 2011 22:46 |  #11
But if you choose center point and focus say on their waist in a low lit place shooting at f2.8 that their faces arent sharp/focused?
I dont use ai servo mode, but just one shot mode and I find out points to be just fine on the 5dm2.
www.sidd-rishi.com.au (external link)http://www.sidd-rishi.com.au (external link)
form
"inadequately equipped"
Mar 17, 2011 23:31 |  #12
Background blurring = wide aperture = I will use the 85L 99% of the time and rarely do full-body shots that show the feet because I don't typically see it as aesthetically pleasing.
Las Vegas Wedding Photographer: http://www.joeyallenph​oto.com (external link)
DingAnSich
Mar 18, 2011 02:27 |  #13
can"t you just lock focus and recompose?
www.dingansic.com (external link)
highway0691
Mar 18, 2011 02:44 |  #14
DingAnSich wrote in post #12042362 (external link)
Could be problematic with a moving subject.
tonylong
...winded
Gallery: 60 photos
Mar 18, 2011 02:56 |  #15
I think people overplay using the outer points. I shot these at f/1.2 in a gymnasium a couple weeks ago:
IMAGE: http://www.pbase.com/tonylong/image/132962093.jpg
IMAGE: http://www.pbase.com/tonylong/image/132962124.jpg
And many more at f/2.8.
When shooting wide open I would not use the center point and refocus.
Tony
2,638 views & 0 likes for this thread
Latest registered member is atomanth
803 guests, 213 members online
