porky101 wrote in post #12055029
Hi Viet,
Thanks for your reply...
About the Halo and blowing out her hair , I was aware of them both....I wanted lots of blur but with my minimum F ratio of 4 I dont get much so I did that in photoshop , I slightly over exposed the image aswell.
Next time, pick a better location, under the shade somewhere. To start out, always put them in the shade, that way you don't blow their faces. The rest can blow, but not the faces, especially for portraits.
F4 is fine if you want your heavily out of focus background. Think about it for a moment, it's called "out of focus" or bokeh for a reason. If you don't have a long lens, then put them somewhere with the background further back. With the right focal length vs subject distance, you can "blur" as much as you want. Keep in mind, pp should be an after thought unless you know what you are looking for.
About the inconsistent exposures.... every shot I shot was on manual and I metered for each shot on my own by taking a picture and then looking for a balanced histogram.....but I did that with every shot.....are you saying that I must shoot 1 exposure setting shot and then leave it.....? so I dont adjust the exposure again to get them "consistent" all of those shots were in the SAME room at the same time.....
Manual doesn't really mean anything if you can't get it consistently. Consistently for your level right now, means that you should try to get them to look about the same in every shot, not too bright as to blow it out, and not too dark. Consistent doesn't mean keeping your settings the same everywhere, but knowing where, when and how to tweak it to make everything looks good.
Histogram is a continuation learning process, there's no *right* way to look at the histogram until you know what you are doing.
Most of those are ok exposure wise, but composition & lighting need a lot of work.
I think you should get the Understanding Exposure book and read it over a couple of times, then practice, a lot. You are heading in the right direction, but lacking practice & experience.
