Thread started 19 Mar 2011 (Saturday) 10:52
Why we need more pixels
RDKirk
Adorama says I'm "packed."
Joined May 2004
Mar 19, 2011 10:52 |  #1
An interesting article on Luminous-Landscape:
http://www.luminous-landscape.com/essays/n​ot-so-fast.shtml (external link)
A second reason for more resolution, ironically, is that most lenses are not diffraction limited – they are much worse. The diffraction limit is the best you can do, but most real lenses are worse and have distortion and aberrations, such as coma, chromatic aberration and others. These problems can to some extent be corrected in software – simple versions of this exist in DXO, Camera Raw and other programs today. However all of those adjustments in effect cost you resolution – or conversely you can do a better job with higher resolution sampling. One of the best things you can do with a 100 mp sensor is use it to create a much better 50mp or 25mp image through intelligent down sampling.
One of the points the author makes is that there are many image-enhancing techniques that can be applied through software to correct a multitude of lens faults...but they all carry a "cost" in sensor resolution. Thus, having a surplus of sensor resolution is an overall benefit.
adamo99
Gallery: 6 photos
Mar 19, 2011 11:01 |  #2
I don't print 6x8 foot posters, so I'd be happy if the manufacturers stopped the megapixel race, and concentrated solely on DR and ISO performance.
RDKirk
Joined May 2004
Mar 19, 2011 11:03 |  #3
adamo99 wrote in post #12049805 (external link)
I guess you didn't read the article. Improvements in DR and ISO can come through more pixels.
tonylong
...winded
Gallery: 60 photos
Mar 19, 2011 16:28 |  #4
He makes some interesting points!
I'd be curious to see how the science of binning proceeds. At this point I haven't seen any evidence that the sRaw/mRaw output gives an increase in image quality, but I'd like to see some "smart binning" technology that could, for example, implement CA/fringing corrections or noise reductions in a way that could, say, deliver a cleaner Raw 25MP file from a 50MP sensor -- that could be pretty enticing!
Tony
artyman
Sleepless in Hampshire
Gallery: 17 photos
Mar 19, 2011 17:06 |  #5
I already have smart binnning, ............... if it's no good it gets binned :D
Ken
RobDickinson
Gallery: 14 photos
Mar 19, 2011 17:10 |  #6
People seem to think those goals are mutualy exclusive.
DR and ISO perfomance are pretty much down to sensor area and tech, splitting thta up into whatever numberof pixels is just slicing the same pie a different way
www.HeroWorkshops.com (external link) - www.rjd.co.nz (external link) - www.zarphag.com (external link)
Gear: A7r, 6D, Irix 15mmf2.4 , canon 16-35f4L, Canon 24mm TS-E f3.5 mk2, Sigma 50mm art, 70-200f2.8L, 400L. Lee filters, iOptron IPano, Emotimo TB3, Markins, Feisol, Novoflex, Sirui. etc.
Hogloff
Joined Apr 2003
Mar 19, 2011 19:21 |  #7
RobDickinson wrote in post #12051740 (external link)
Yep, we've seen an improvement in iso performance right along with high pixel numbers. Nothing wrong with wanting more of both.
stevewf1
Mar 19, 2011 20:01 |  #8
Why is 35mm full frame still considered the "standard"? Back in the film days, 35mm was considered a small format. A format for amateurs.
Granted, a camera with a sensor say, twice as big, would result in larger cameras and lenses, but from the way 7D owners sneer at my little "toy" T2i, it seems that a lot of folks would jump at much larger gear...
Steve
tonylong
...winded
Gallery: 60 photos
Mar 19, 2011 22:17 |  #9
stevewf1 wrote in post #12052623 (external link)
Well, medium format is out there, has been out there for some time, and benefits frome the resolution gains as do DSLRs. If you read the article, 100MP MF bodies are in circulation, but the point was made that it is at a real price!
There will always be the APS-C bodies and the 35mm-format "full frame" bodies available at a far lower price (and size) that will handle our DSLR lens/systems so there's nothing wrong with speculating about the potential advantages of higher resolutions as long as Moore's Law stays in effect.
As I mentioned above, I think the concept of "smart binning" is a pretty cool thing to target in the engineering of upcoming generations.
Tony
wec12
Mar 20, 2011 08:44 as a reply to  @ tonylong's post |  #10
Interesting point of view. Thanks for sharing.
Mr.Dissector Photography (external link)
RDKirk
Joined May 2004
Mar 20, 2011 09:01 |  #11
Not exactly a "format for amateurs," but a format with specific applications. Professional PJs were using 35mm by the '30s, and by the early 60s, no major newspapers or magazines were requiring medium format.
National Geographic started publishing 35mm Kodachrome in the '30s as well, and nobody was producing better color plates than they. Up until the 80s, Kodak had a permanent display in Grand Central Station that showcased 35mm Kodachrome backlighted transparent images enlarged to something like 30x50 feet. Those were all professional photographers.
You certainly didn't see any medium format cameras at any NFL or AFL games from the 60s on. Boxing was perhaps the last sport in which medium format was still competitive, but it was gone even ringside by the 70s. Those were professional photographers.
How many medium format camera did you see during the Vietnam War? None. How many amateur photographers were shooting the Vietnam War? None.
By the late 60s, Kodachrome had certainly proven its ability to match medium format Ektachrome in quality even for commercial photography. Medium format hung on in the commercial area primarily because art directors preferred to view it on light tables and contact sheets without needing loupes. But nobody could question the results people like Pete Turner were getting out of their Nikons.
1950 - The company unveiled the first in its long-running series of KODAK COLORAMA Display transparencies - 18 feet high and 60 feet wide - overlooking the main terminal floor of Grand Central Station in New York City. An estimated 650,000 commuters and tourists viewed this popular attraction every business day, and many of the dramatic photographs displayed over the years were the subject of widespread newspaper and magazine coverage. The exhibit was permanently dismantled in early 1989 as part of Grand Central's restoration.
http://www.kodak.com …historyOfKodak/​1930.jhtml (external link)
hollis_f
Mar 20, 2011 12:39 |  #12
35mm?
Oh, you mean 0.625 crop cameras!
Well, I'm sure APS-C outnumbers 'full-frame' so it should be the new standard.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
SaxonIV
Mar 20, 2011 17:09 |  #13
RDKirk wrote in post #12055143 (external link)
what does that even mean? This just made me doubt any of your other points...
my Friends dad has an entire box of slides from the vietnam war...
quiksquirrel
Joined Mar 2011
Mar 20, 2011 17:34 |  #14
Instead of constantly focusing on pixels in our DSLR's, I really wish that manufactures would work on bringing down the prices of digital MF.
I honestly believe that the market is ready for semi-pro MF gear, in a price range of $5000-10000,-
If super high resolution is the goal, MF is the platform.
With DSLR's, what I want to see, is better dynamic range, better high ISO performance and generally better use of the pixels we already have.
RDKirk
Joined May 2004
Mar 20, 2011 18:45 |  #15
SaxonIV wrote in post #12057704 (external link)
Was he there on his dime or the government's?
Yes, okay, I'll give you that point. My father has personal photos from both the Vietnam War and the Korean War. However, he did not go either to Vietnam or Korea for the purpose of taking photos as an amateur, he went for the purpose of killing people.
My point was that the professionals PJs shooting the Vietnam War were using 35mm cameras, so the format is not an "amateur's format." If you don't believe that, it's easy enough to Goggle it.
3,048 views & 0 likes for this thread, 12 members have posted to it.
1451 guests, 128 members online
