Thread started 19 Mar 2011 (Saturday) 15:11
Sky Replacement
Bentapp2
Joined Mar 2011
Mar 19, 2011 15:11 |  #1
Ok, so i've seen a few techniques on turning grey skies blue, but is there an easy way to do it when you have a lot of branches, little grey spots (see picture below)? I'm not great at this end of photoshop, so any help would be appreciated!
http://i84.photobucket​.com …edding_canvas_p​hoto_1.jpg (external link)
Quad-Response
Mar 19, 2011 16:40 |  #2
I used removed the 'old' sky and replaced it with something a little more 'Summery'
HTTP response: 403 | MIME changed to 'text/html'
Took about 5 minutes :)
Is this what you were after?
Chris
Canon EOS 1D Mark II for Sale - £450.00 ONO - PM For Details or see the Members Market
Steve ­ Ruddy
Mar 19, 2011 16:47 |  #3
Since all the colors touching the sky are a totally different color you may have good luck using select/ color range then make your color correction to it.
Steve Ruddy Photography (external link)facebook - Steve Ruddy Photography (external link) | | Flickr Photostream (external link)Fine Art America (external link)
5D MK IV | 80D | EF 24-105MM F-4L IS USM | EF-S 17-55mm F/2.8 IS USM | EF 100mm F/2.8 Macro USM | Tokina SD 16-28mm F2.8 | EF 70-200mm F/4L IS USM
Kolor-Pikker
Mar 19, 2011 16:58 |  #4
Depending on the sky, you can luck out and not even have to do any masking or using color range, just by using the blend-if sliders in layer styles.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
Steve ­ Ruddy
Mar 19, 2011 17:11 |  #5
Kolor-Pikker wrote in post #12051664 (external link)
I just learned about that a few days ago I agree it may may work for you.
ssim
Joined Apr 2003
Mar 19, 2011 18:46 as a reply to  @ Steve Ruddy's post |  #6
CS5 has made great improvements in making selections, even for fine hairs or leaves that you see in your shot. There are many online tutorials that are easy to find. If you are using a version of photoshop previous to CS5 I would suggest that you should use the method of using channels to do your selections, again lots of online tutorials can be found. These are the way I would do this and that is not to say anything against what others have suggested, just my way of going about it.
Gipetto
Mar 20, 2011 02:40 |  #7
Because of the leaves there I'd recommend using a channel based selection method. Like so: http://graphicssoft.ab​out.com …toshop/l/blrbps​_2fwks.htm (external link)
blog (external link) | gear | photos: zenfolio (external link), flickr (external link)
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Mar 20, 2011 08:30 |  #8
Oh you don't need a selection for this. Just put the tree layer on top of the sky layer and set the blend mode to Darken.
All that being said, no one has mentioned the HARDEST AND MOST DIFFICULT TO MASTER step in the whole process. That step is, "Using a sky shot that matches the main shot." You will soon discover the disappointment of dropping just any set of blue sky/puffy clouds into any gray sky and have it look like crap, but you don't quite know why. In order to do this well, the shots should match - or at least be believable - on many different criteria, including but not limited to:
Lighting direction. If the clouds are lit from the right and the main shot is let from the left (or not at all), it will look obviously fake.
Color temperature. If the clouds are from a nice golden sunset and the main shot is from a cold December morning, it will look obviously fake.
Perspective. If the clouds were taken with a 28mm wide angle lens, and the main shot is from a from a 200mm telephoto, (or verse visa) it will look obviously fake.
Tons of other things I don't want to bother typing. If the clouds are one thing, and the main shot is another, it will look obviously fake.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
Peano
Mar 20, 2011 08:49 as a reply to  @ Radtech1's post |  #9
This is a simple approach. The only accurate selection required would be along the straight edges of the chimney and roof.
IMAGE: http://img825.imageshack.us/img825/2007/skyfix.jpg
Peano
RadiantPics.com (external link)
Radtech1
Joined Jun 2003
Mar 20, 2011 08:56 |  #10
Peano is absolutely right about the sky being lighter on the horizon. (Follow his link and read it). That is one of the "tons of other things", but next time someone asks this, I think that it will rise to being mentioned. It really makes or breaks the believability.
Rad
1,274 views & 0 likes for this thread, 8 members have posted to it.
Sky Replacement
2808 guests, 164 members online
