Thread started 19 Mar 2011 (Saturday) 16:03
Sizing
drdiesel1
Gallery: 86 photos
Mar 19, 2011 16:03 |  #1
How can I make an image 1600x1060 ? I have a full size image to work with @ 4536x2832 I'm not worried about how it fits in relation to whats in the image. I want it to be 1600x1060 layout.
I have CS5 ans LR3 as editing software.
Thanks :cool:
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
Steve ­ Ruddy
Mar 19, 2011 16:57 |  #2
Using PS in the image size dialog box leave proportions constrained and resize height to 1060. Then all you will have to to do is crop to 1600. Look at your info panel while cropping to see what the dimensions are.
Steve Ruddy Photography (external link)facebook - Steve Ruddy Photography (external link) | | Flickr Photostream (external link)Fine Art America (external link)
5D MK IV | 80D | EF 24-105MM F-4L IS USM | EF-S 17-55mm F/2.8 IS USM | EF 100mm F/2.8 Macro USM | Tokina SD 16-28mm F2.8 | EF 70-200mm F/4L IS USM
drdiesel1
Gallery: 86 photos
Mar 19, 2011 17:08 |  #3
Steve Ruddy wrote in post #12051654 (external link)
It's locked to the width and when I set it to 1060 it brings the width down too.
EDIT. I see the Constrain Proportions is ticked.
Thanks for the help.
Steve ­ Ruddy
Mar 19, 2011 17:39 |  #4
If you don't keep the proportions constrained your image will be distorted hence the second step to crop the remaining width to 1600
drdiesel1
Gallery: 86 photos
Mar 19, 2011 17:50 |  #5
Steve Ruddy wrote in post #12051908 (external link)
Yep, I found out :lol: Thanks again
tzalman
Fatal attraction.
Mar 19, 2011 17:55 |  #6
LR3: Custom crop, put in the numbers 1600 and 1060.
Export, with resize.
Elie / אלי
Wilt
Mar 19, 2011 18:31 |  #7
Or simply define a square crop in LR (e.g. 2832 x 2832) , then specify at time of Export of a JPG file, with output parameter of 1600 x1600 pixels
drdiesel1
Gallery: 86 photos
Mar 19, 2011 20:48 |  #8
tzalman wrote in post #12052014 (external link)
I'll take a look at that ;)
tonylong
...winded
Gallery: 60 photos
Mar 19, 2011 20:59 |  #9
drdiesel1 wrote in post #12052892 (external link)
I'd say that would be the "less muss, less fuss" way -- LR will give you a crop rectangle with the proper proportions than you can then resize for your composition and then when you Export it you leave Constrain Proportions checked and just set one of the dimensions and the other should fill in properly. This way you stay in the Raw workflow if you don't need to go into Photoshop.
Tony
drdiesel1
Gallery: 86 photos
Mar 19, 2011 21:24 |  #10
tonylong wrote in post #12052955 (external link)
OK, Thanks. Good info guys 8-)
tzalman
Fatal attraction.
Mar 20, 2011 05:09 |  #11
... when you Export it you leave Constrain Proportions checked ...
LR doesn't have a Constrain Proportions box. You can't not constrain.
Elie / אלי
tonylong
...winded
Gallery: 60 photos
Mar 20, 2011 11:47 |  #12
Ah, OK, I was thinking of the PS Image Size resizer!
Tony
1,828 views & 0 likes for this thread, 5 members have posted to it.
Sizing
906 guests, 122 members online
