Here's one of my wife. C&C please.
DanThoman Goldmember 2,646 posts Likes: 124 Joined Aug 2009 Location: georgia lake country More info | Mar 20, 2011 16:20 | #1 |
CBJammin103@gmail.com Mostly Lurking 13 posts Joined Dec 2007 More info | Mar 20, 2011 16:23 | #2 At a glance seems a little soft (maybe even missed focus a little bit? could also be jpg compression, though...) and seems like the background needs to be more separated from the subject. So either a wider aperture or a bigger distance between the subject and the bg.
moeronn Goldmember 2,516 posts Joined Feb 2008 Location: SoCal More info | Mar 20, 2011 18:53 | #3 This is a good start, but if I may offer a few suggestions... First, your lighting appears to be too even and it is a little underexposed. Leave one light at the same power and boost the power on the other (key) light. I'd also raise the key up to get the catch light around 10:00 or 11:00. Also, try turning your wife/model so she isn't so square to the camera. Try different angles from both the left and right. Lastly, try shooting from a slightly higher point of view. Not too high, but have the lens at about eye level or slightly higher.
kilr95ss Senior Member 713 posts Likes: 62 Joined Oct 2008 Location: Clanton, AL More info | The head on shots are usually never flattering, have her turn 45* to the camera and look back at you next time. Charles Spradley
mpadula Senior Member More info | Too much blue in the photo.. The shirt blends in too much with the background screen and in my opinion maybe a different color background would have been better. I don't have enough experience to comment on much else since I am still learning about photography and I like to do mostly nature/wildlife photos, but that is just what stood out in my mind when I first saw the photo at a quick glance.
collierportraits Goldmember 1,896 posts Likes: 3 Joined Mar 2008 Location: Virginia Beach, USA More info | Mar 20, 2011 20:24 | #6 Several points: some have already been mentioned. 5D3 | 16-35L | 45 TS-E | 50L | 85L | 100L | 135L | 24-70L | 70-200 II L | 580s | Zero, TT & Crumplers | and an X100!
| Latest registered member is semonsters 926 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
