Amnesia180 wrote in post #12057540
Thanks for the advice.
When I make sure those two options are checked, I change the DPI from 72 to 300 and it makes the file size over 400mb and puts the image to over 10,000+pixels in either direction... this is surely too large?
Let me try to put this another way, to explain what you are doing.
You say your image is 3624 x 2416. It is also 72 dots per inch. Simple math puts that as a "native size" of 50.3 inches x 33.5 inches. (3624 x 2416 divided by 72 dots in each inch.) Or put even another way, you know the edge that is 3624 pixels long? Imagine you start counting pixels. Every 72 pixels you move into the next inch. 3624 pixels is 50.3 inches.
Are you with me so far?
OK.
Now Photoshop has a picture that measures 50.3 inches by 33.5 inches. You then tell Photoshop that you want 300 pixels per inch, not 72. Well, then, Photoshop has to ask itself, "How many pixels, at 300 per inch, will I need to get to 50.3 inches?" The answer is 15,100 pixels along the long edge, and 10,050 on the short edge.
See, if you don't specify a size, it will keep the size (50.3 inches by 33.5 inches) that it thinks you want.
So, if you want to resize, enter a size, in inches as well as the DPI that you want. When you do that, you will get what you want.
Totally clear?
Rad
