I've read in the manual (of my 300mm f/4L) that IS should be turned off when using a tripod or you will get unexpected results. But then again, I remember reading somewhere that some photographers doesn't turn IS off even when using tripods.
If I use a tripod and a remote shutter release, do I need to turn off IS?
Can you share your real world experiences on this?
Also, I would assume that the case will be different when using a monopod?
