Thread started 20 Mar 2011 (Sunday) 22:31
need help... what else (lens) should be in my bag? (realistic)
tagakweens
Mar 20, 2011 22:31 |  #1
I have:
Canon 24-70L f/2.8
50mm f/1.8
Tokina 11-16
don't really have the budget right now, I'm thinking of getting:
canon 55-250 (for the telephoto zoom part)
I also know there'a a big gap between 16 and 24...
if I do get the 55-250, what else should I get?
Thanks..
antonyfortuna
Joined Mar 2011
Mar 20, 2011 22:31 |  #2
budget??
tagakweens
Mar 20, 2011 22:36 |  #3
under $400
jaspa
Joined Mar 2011
Mar 20, 2011 22:41 |  #4
55-250s a decent cheap lens, with that budget Id say that if you simply want FL... does the 85mm 1.8 interest you at all? What do you shoot?
- Jason -
tagakweens
Mar 20, 2011 22:45 |  #5
mostly my kids, portrait...
i would use my tokina for nature/landscape shot..
kwando
Mar 20, 2011 22:47 |  #6
why not wait a little more to raise your budget to $500 and get the 70-200 F4L (non IS)
~Simon~
My Gear | My Feedback | Smugmug (external link)
https://photography-on-the.net …/showthread.php​?t=1213134
tagakweens
Mar 20, 2011 22:53 |  #7
kwando wrote in post #12059783 (external link)
i thought about that instead of getting the 55-250, but the price difference is almost $400 plus the "L" lens doesn't have IS
Ken ­ Nielsen
Joined Jun 2004
Mar 20, 2011 23:00 |  #8
You simply need to pin down what you need a lens for first. Canon pretty much will have you covered. You don't mention Macro, I had the 60mm Macro for a while and got some nice portrait-type shots with it and then you also get the close-up ability with it too. I didn't use it that much and took it back within the return period. One man's treasure is another man's paper weight. I would save up and get the 500mm f/4, but that's me.
Point; Pinpoint your exact need: What do you like to shoot a lot of shots of? You may already have everything you need. Seems to me the 17-55 would be a better lens for you than the 24-70, but you are the final judge of that.
Ken
TheBrick3
Mar 20, 2011 23:06 |  #9
I don't think you should worry about the gap between 16 and 24. You should buy a flash, but failing that a 70-200 f/4 is the wiseest move. Skip the 55-250.
tagakweens wrote in post #12059714 (external link)
under $400
I hate it when this forum says if you expand the upper limit of your budget just a little bit you can get the L, but with enough patience and a little luck you can find a 70-200 f/4 on these forums for about $450. You do have a keep the shuttle speed up, but it's a fantastic lens.
1D III 5D II 5D | 580 EX II x 2
17-40L | 35L | 100L | 70-200 II | 17-35 f/2.8-f/4
Website (external link)
Fricks
Mar 20, 2011 23:43 |  #10
++1
yourdoinitwrong
Mar 21, 2011 08:29 as a reply to  @ Fricks's post |  #11
If your budget is not flexible or you need something soon then you are probably on the right lens with the 55-250. It seems like anything in photography is always a compromise between budget and needs/wants. If you plan on using the lens indoors very much then the IS is going to be a help, but won't help stop motion of an active child. I ended up getting the 70-200 f/4 because I knew it would be used mainly outdoors where a wider aperture and IS weren't going to be as necessary. So if you are sure the 55-250 fits your needs then go for it, however if you aren't sure then wait until you can purchase exactly what you need. To me it's better to delay a purchase and end up happy than spend somewhat less and have buyer's remorse.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
1,295 views & 0 likes for this thread
Latest registered member is abouthuanyu
2133 guests, 214 members online
