Thread started 28 Sep 2005 (Wednesday) 06:13
Monitor Funny buggers pt2.
MattyB
Sep 28, 2005 06:13 |  #1
my monitor was dropped recently, then the colours changed, and i couldn't fix it, everyone was darker and more saturated (still is)
now, this thread varies alot from my previous one because of the storms melbourne is suffering tonight.
the computer switched off, and wouldn't turn back on for a good 30 minutes, that was when i relised it was a safety switch, fixed it, and turned on the computer
as it loaded VERY VERY slowly, the monitor was back to the normal colours and lightness. it looked normal again
but.. 30sec-1min later, it flicked over to dark saturated again..
my computer was lagged, it switched over while it was loading everything up.
so this gets me to thinking that it's that stupid adobe whatever thing thats loading again, - *remembers, checks*, oh.. adobe gamma loader is in my start up folder in the start bar yet again
yay, now all i need is one of you lot to tell me how to take it out of start up!
haha, and - is there a preset adobe gamma or other fixy-ma-doobee that will make my colours perfect for viewing your photos? :D
thanks
Matt Bennell
Camera: Canon EOS 80D DSLR Black
Extras: 18-55mm, 10-18mm, Tripod, ND8
Field: These days you'll likely be seeing plenty of Nature and Landscape posts :lol:
New Site In Progress -> bennell.co.nz (external link)
EricKonieczny
Joined Jan 2005
Sep 28, 2005 08:54 |  #2
http://www.adobe.com/s​upport/techdocs/321608​.html (external link)
What Adobe Gamma Does
By calibrating your monitor at the system level, Adobe Gamma enables you to eliminate unwanted color casts from your monitor and to obtain the best display possible for your work environment. In addition, Adobe Gamma characterizes your monitor by means of an ICC profile, which is a file that includes a description of the characteristics of your monitor. This profile can be used by any application that uses ICC profiles to compensate for a monitor's color-display limitations. Accurately calibrating and characterizing your monitor is the crucial first step in developing a color-managed workflow.
How Adobe Gamma Works
The Photoshop installer installs Adobe Gamma control panel (Adobe Gamma.cpl) into the Windows/System folder (Windows Me and 98) or the Program Files/Common Files/Adobe/Calibratio​n (Windows XP and 2000), and it installs the Adobe Gamma loader application (Adobe Gamma Loader.exe) into the Program Files/Common Files/Adobe/Calibratio​n folder. In addition, it installs a shortcut to the Adobe Gamma Loader application in the Windows/Start Menu/Programs/Startup folder (Windows Me and 98) or the Documents and Settings/All Users/Start Menu/Programs/Setup (Windows XP and 2000). As a result, the Adobe Gamma loader application appears in the Start > Programs > Startup menu and starts automatically during Windows startup.
While loading Adobe Gamma.cpl during Windows startup, the Adobe Gamma Loader application applies settings in the Adobe Gamma.cpl file to the system and applies calibration settings you saved for your monitor at the system level.
How to Use Adobe Gamma
To calibrate your monitor and create an ICC profile in Adobe Gamma:
1. Choose Start > Settings > Control Panel.
2. Double-click Adobe Gamma.
3. Select Step By Step Wizard, and then click Next.
4. In the Description text box, type a name for the profile. Type a name you will easily identify, such as the monitor name and the date. (When you save the profile at the end of the wizard, you need retype the name.)
5. Click Next, and then follow the on-screen instructions. Before you save the settings, you can use the Before and After buttons to see how the changes you made affect the monitor's display.
After you create the ICC profile, Adobe Gamma saves it in the following folder (along with all other ICC profiles):
-- Windows/System/Color folder (Windows Me and 98)
-- Windows/System32/Spoo​l/Drivers/Color folder (Windows XP)
-- Winnt/System32/Spool/​Drivers/Color folder (Windows 2000)
For more information, see the Photoshop online Help, or see "Creating an ICC monitor profile" on page 136 of the Photoshop 6.0 user guide .
Adobe Gamma and Third - Party Monitor Calibration Utilities
If you already have a monitor calibration utility installed, and it can create ICC profiles, you should either disable the other utility or prevent Adobe Gamma from applying its settings at the system level when Windows starts. This step prevents the two from conflicting and causing an inaccurate display. To disable a third-party calibration utility, refer to the documentation included with it.
To prevent Adobe Gamma from loading its settings at startup , remove Adobe Gamma Loader:
-- Windows XP and 2000:
1. Double-click My Computer.
2. Navigate to Documents and Settings/All Users/Start Menu/Programs/Startup.
3. Select Adobe Gamma Loader, and drag it onto the desktop.
- Windows Me and 98:
1. Choose Start > Settings > Taskbar and Start Menu Properties (Windows Me ), or choose Start > Settings > Taskbar (Windows 98).
2. Click the Advanced tab (Windows Me ) or the Start Menu Programs tab (Windows 98).
3. Click Remove in the Customize Start Menu section (Windows 98), or click Remove in the Start menu section (Windows Me).
4. Double-click Programs if it isn't expanded, and then double-click StartUp.
5. Select Adobe Gamma Loader.exe, and click Remove.
6. Click Yes if asked if you want to remove this item (Windows 98).
7. Click Close in the Remove Shortcuts/Folders dialog box, and then Click OK in the Taskbar Properties dialog box.
Note: After you remove Adobe Gamma Loader from the StartUp folder, Adobe Gamma is still be available in the Control Panel, but its settings aren't loaded when Windows starts. Photoshop continues to use Adobe Gamma to access the monitor profile you specified.
If you create a profile in a third-party monitor calibration utility, Adobe recommends that you load that profile in Adobe Gamma:
3. Select Control Panel, and then click Next.
4. Click Load to the right of the Description text-box.
5. Navigate to the folder that contains the profile you want to load:
-- Windows/System/Color (Windows Me and 98)
-- Windows/system32/spool​/drivers/color (Windows XP)
-- Winnt/system32/spool/d​rivers/color
6. Select the profile created by your third-party monitor calibration utility, and click Open.
7. Click OK in Adobe Gamma.
8. Click Save when the message, "Save changes to the profile [profile nam e.icm] before closing?" appears. After you close Adobe Gamma and click Save, the profile * will be available to Photoshop.
How Photoshop Uses Profiles
Photoshop uses profiles as follows:
-- Photoshop 7.x optimizes the displ ay of images by using the ICC monitor profile, a source document profile (if one is assigned to the image), and the application's working space profile. To determine which profile is embedded in an image, choose Document Profile from the pop-up menu in the status bar (located at the bottom edge of the document window). To determine the current working space profile, choose Edit > Color Settings, and then note the RGB profile in the Working Spaces section.
-- Photoshop 6.x optimizes the display of images using the source document profile (if one is embedded in the image), and the ICC monitor profile. To determine which profile is embedded in an image, choose Document Profile from th e pop-up menu in the status bar (located at the bottom edge of the document window).
Note: Monitor Compensation is always on and cannot be turned off in Photoshop 6.x.
EKREATING photography - capture the feeling! (external link)
20D w/Grip|28-105 f3.5-4.5|70-200 f2.8L IS|10-22|580EX w/ ST-E2|Tripod 3021BPRO w/ 488RC2 Midi Ballhead & TC-80N3 Remote|Archos GMini 400|Tamrac Expedition 5
DavidW
Sep 30, 2005 11:12 |  #3
Adobe Gamma, if used properly, allows you to get some way towards a calibrated monitor. If you want proper calibration, your only option is to use one of the software plus hardware calibration packages, such as Monaco OPTIX XR, or Gretag-Macbeth's bottom end solution.
You must have some really weird settings in Adobe Gamma for it to be doing what you describe.
David
DocFrankenstein
Joined Apr 2004
Sep 30, 2005 23:32 |  #4
I once pressed Ctrl+Alt+Down and had to reinstall windows because I could not figure out what happened.
National Sarcasm Society. Like we need your support.
991 views & 0 likes for this thread, 4 members have posted to it.
1708 guests, 100 members online
