Thread started 21 Mar 2011 (Monday) 18:13
Head shot with infinity background: Would this work?
pxchoi
Mar 21, 2011 18:13 |  #1
Okay, so my friend needs a professional looking head shot done with a white backdrop.
In my head, I'm thinking about using 2 flashes. One to expose my subject and the other to over expose my background.
My plan is to use maybe a white bed sheet and hit it with flash (430EXII) from behind and to use a 580EXII to expose my subject.
My only issue is, I don't have a wireless flash trigger and if the 430EX is behind the sheet, it will be out of the line of sight from my 580EX.
So, I'm thinking about using a Sync Cord to use with my 480EX and wanted to figure out which one I was going to need and around how much they cost. I read that with a Sync Cord, I won't be able to use TTL but I don't think that will be an issue when exposing a white background.
Other suggestions are welcomed.
Patrick Choi
Portfolio (external link) | Flickr (external link) | Facebook (external link)
EOS 7D | 580EX II | 10-22mm f3.5-f4.5 | 17-55mm f/2.8 IS |70-200mm f/2.8L IS II
For Sale: 17-55mm f/2.8 IS | 10-22mm f3.5-f4.5
JonK
Joined Feb 2004
Mar 21, 2011 18:15 |  #2
Instead, use a white board or paper and hit it with the flash from in front, but behind or above the subject. If you shoot a bed sheet from the back you risk highlighting its non-white areas since its not a uniform thickness. The only way around it is with a large light with a VERY bright output, but then you have an awkward back light. Shoot it from the front, overexpose the flash on the back ground until you get it how you want, then bring in the subject and 2nd flash.
7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
check my blog:
www.jonkensy.com (external link)
pxchoi
Mar 21, 2011 18:19 |  #3
JonK wrote in post #12064977 (external link)
Good tip. My only concern is how am I going to get a piece of white paper big enough to use as a back drop.
Patrick Choi
arentol
Mar 21, 2011 18:27 |  #4
JonK is right on the money I think.
I personally would just use the 580 off-camera left (or right), far enough back for its signal to reach the 430. This is made easier by it being just a head shot, which means the 430 could actually be slightly to the side of the subject. Then I would use a reflector or flash on the opposite side for fill.
Important thing is to have a white fairly non-reflective background and at least 2 flashes. After that it is pretty easy.
Just go down to your local photography store and purchase a roll of paper there. Shouldn't cost very much.
5D3 | Rokinon 14 f/2.8 | 16-35L II | TS-E 24L | Tamron 24-70 f/2.8 | Tamron 28-75 f/2.8 | Voigtlander 40 f/2.0 | Σ 50 f/1.4 | MP-E 65 | 70-200 2.8L IS II | Σ 85 f/1.4 | Zeiss 100 f/2 | Σ 120-300 f/2.8 OS | 580 EX II | 430 EX II | Fuji X10 | OM-D E-M5 | http://www.mikehjphoto​.com/ (external link)
*****Lenses For Sale (external link)*****
Silverfox1
Mar 21, 2011 19:52 as a reply to  @ arentol's post |  #5
If your not doing the shoot this weekend why not consider the below since your describing 1 subject shots and this will be wide enough:
http://www.bhphotovide​o.com …ess_Background_​Paper.html (external link)
Regards, ;)
Silverfox1 POTN Feedback / TC Extender Tests / Gear List
drdiesel1
Gallery: 86 photos
Mar 22, 2011 03:46 as a reply to  @ Silverfox1's post |  #6
Do you have a softbox ? I shoot against my 24x24 softbox tilted up at a 45 degrees for just headshots.
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
monkeymike
Mar 22, 2011 08:10 |  #7
drdiesel1 wrote in post #12067851 (external link)
a white reflector also works...
~mike
| 50D | 7Dii |
| 10-22 | 17-40 | 28-135 IS | 70-200 2.8 IS |
| 50 1.4 |
| 430EX II | 055XPROB w/ 488RC2 | 680B w/ 234RC |
aaron.dunlap
Mar 22, 2011 09:46 |  #8
monkeymike wrote in post #12068349 (external link)
~mike
and on that note.... here's everyone's favorite budget reflector:
http://www.amazon.com …TF8&qid=1300805​124&sr=8-1 (external link)
i have one... they are indispensable.... at $13, its a no-brainer.
 Aaron
Benji
Mar 22, 2011 13:51 |  #9
Put the sheet in front of a window that has sunlight streaming through it. Meter the sheet. Add enough flash to the subject's face so it will be two stops under the background reading. For example the sheet meter reading is f/11 @ 1/125. Meter the flash so it is f/8.0 @ 1/60.
Benji
HughR
Mar 22, 2011 14:11 |  #10
pxchoi wrote in post #12064964 (external link)
The 7D does have a wireless flash trigger using the on-camera pop-up flash. I have the 60D with essentially the same system. Indoors in a moderate sized room I have often triggered my 430EX when it is entirely out of the line of sight. Reason is that the control signal reflects off surfaces. So you should be able to trigger both of your flashes off camera using your 7D with no problem. Give it a try.
Hugh
Canon 60D, Original Digital Rebel (2003)
EFS 15-85mm IS USM, EF 70-300mm IS USM, Tokina 11-16mm
Speedlite 430EX, Speedlite 430EX II,
Qbox 16 pro, Lastolite EZbox 24x24, Lumiquest Softbox III
3,358 views & 0 likes for this thread, 9 members have posted to it.
2699 guests, 138 members online
