A friend told me that I can use my Hasselblad lenses via an adapter to fit my Canon body (5D and 40D). I need your opinion and suggestion before I take this step. Apparently the adapter is manufactured in The Ukraine (reliable?).
Thanks for the tip.
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | Mar 22, 2011 22:23 | #1 A friend told me that I can use my Hasselblad lenses via an adapter to fit my Canon body (5D and 40D). I need your opinion and suggestion before I take this step. Apparently the adapter is manufactured in The Ukraine (reliable?). www.eaglesnestphotography.com
jaycky Goldmember 2,089 posts Likes: 1 Joined Aug 2010 Location: Bancouver okanagan alberta More info | Mar 23, 2011 00:50 | #2 please post pictures when its on i would love to see the outcome 5DM2 /grip Lots Of L's
gibbit1 Goldmember 1,658 posts Likes: 7 Joined Jul 2009 Location: Valdese, nc More info | Mar 23, 2011 06:21 | #3 I don't know about Hasselblad, but I've successfully adapted Pentax and Zeiss lenses to my Canon bodies with no issues. I believe the adapters I bought were made in China, but I'm not sure. The only issue you'll need to worry about is whether or not the lens protrudes into the camera body enough to interfere with the reflex mirror. If you're using a crop-body camera, this probably won't be an issue. "Everything will be alright. I'm from the government and I'm here to help."
Mark_48 Goldmember 2,068 posts Joined Nov 2004 Location: Brookfield, MA More info | I have an adapter for using Mamiya 645 lenses on Canon bodies and it works well, so a Hasselblad lens should be fine. Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
apersson850 Obviously it's a good thing More info | Is it a good idea? Lenses designed for larger formats tend to have less resolution in line pairs/mm, since they don't have to, normally. But in a case like this, that would be wasted outside the sensor. Anders
| Latest registered member is ANebinger 1067 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
