is this the correct way
crop/resize/edit,sharpen/save.?
bckane Senior Member 885 posts Joined Mar 2007 Location: Miramar, Fla More info | Mar 23, 2011 11:59 | #1 is this the correct way Brian
gonzogolf dumb remark memorialized More info | Mar 23, 2011 12:04 | #2 What do you mean by edit? If you mean significant changes to the image, then that should be done to the full res image, then the steps in the order you suggest.
Mar 23, 2011 12:14 | #3 I crop/edit/resize/sharpen/save. Canon T3I 6D 24-105L 100-400L Canon 430EX
Mar 23, 2011 12:16 | #4 edit.? Brian
windpig Chopped liver More info | Mar 23, 2011 12:17 | #5 Stargazerfrank wrote in post #12076878 I crop/edit/resize/sharpen/save. I do this but with some capture sharpening to this at the begining. Would you like to buy a vowel?
Mar 23, 2011 12:18 | #6 Stargazerfrank wrote in post #12076878 I crop/edit/resize/sharpen/save. this sounds good Brian
gonzogolf dumb remark memorialized More info | Mar 23, 2011 12:21 | #7 bckane wrote in post #12076885 edit.? like exposure corrections, levels and so on so this should be done with full image then crop then resize then sharpen.? Yes, because that leaves you with a full res image, with edits intact, for later use. For instance if you followed your initial path and resized before editing, and then you wanted to post here, and print, and then perhaps use in some fashion requiring a smaller size (smart phone background). You would have to edit it for each shot. If you edit first, then crop, resize, etc. then you can save the full size file and make your various resizes from a common (edited) starting point.
Mar 23, 2011 12:30 | #8 gonzogolf wrote in post #12076919 Yes, because that leaves you with a full res image, with edits intact, for later use. For instance if you followed your initial path and resized before editing, and then you wanted to post here, and print, and then perhaps use in some fashion requiring a smaller size (smart phone background). You would have to edit it for each shot. If you edit first, then crop, resize, etc. then you can save the full size file and make your various resizes from a common (edited) starting point. Thanks great info Brian
tonylong ...winded More info | Mar 23, 2011 13:30 | #9 Cropping is something that can take different approaches. Tony
Mark-B Goldmember 2,248 posts Likes: 10 Joined Jul 2007 Location: Louisiana More info | Mar 23, 2011 16:50 | #10 Crop/Straighten Mark-B
Peano Goldmember 1,778 posts Likes: 133 Joined Aug 2007 More info | Mar 23, 2011 18:56 | #11 |
trouthunter Member 229 posts Joined Feb 2011 Location: Niagara Region More info | Mar 24, 2011 10:26 | #12 This is good info, just curious on why you would sharpen at the end of the process? I usually sharpen during the edit process. I am glad I have learned something thank you all. 5D Mark 2, 7D, Canon 70-200 F4L IS , Sigma 17-70 OS, Nifty Fifty, 50 1.4, Speedlite 430 ex2. Einstein 640 x 2
gonzogolf dumb remark memorialized More info | Mar 24, 2011 10:28 | #13 trouthunter wrote in post #12083164 This is good info, just curious on why you would sharpen at the end of the process? I usually sharpen during the edit process. I am glad I have learned something thank you all. When you resize an image compression can take its toll so you may want to sharpen again after resizing.
tonylong ...winded More info | Mar 24, 2011 10:41 | #14 trouthunter wrote in post #12083164 This is good info, just curious on why you would sharpen at the end of the process? I usually sharpen during the edit process. I am glad I have learned something thank you all. gonzogolf wrote in post #12083175 When you resize an image compression can take its toll so you may want to sharpen again after resizing. In addition, any people sharpen when they are preparing a photo to print after resizing it to the proper print size. Tony
Mar 24, 2011 11:26 | #15 seems Im getting the hang of this now...its all coming together Brian
| Latest registered member is MWCarlsson 913 guests, 182 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
