Just thought I might post this random shot I took at an event I covered on the weekend. This bloke writes for a national regional newspaper. I guess this lens is a little too heavy to hold. I must say though it looks like a mini 400mm.
Matt-EM Hatchling 6 posts Joined Mar 2011 More info | Mar 24, 2011 00:25 | #1 Just thought I might post this random shot I took at an event I covered on the weekend. This bloke writes for a national regional newspaper. I guess this lens is a little too heavy to hold. I must say though it looks like a mini 400mm. Gear: Canon - 1D MarkIV, 400 2.8, 300 2.8, 70-200 2.8, 24-70 2.8, 15-35 2.8, 85 1.2, 580EX II and much more.
asysin2leads I'm kissing arse 6,329 posts Likes: 3 Joined Dec 2006 Location: Lebanon, OH More info | Mar 24, 2011 00:28 | #2 I believe that's the 300 f/4. Kevin
Cozmocha Senior Member 728 posts Likes: 5 Joined Oct 2010 More info | Mar 24, 2011 00:36 | #3 It's a 400 5.6 -Kurt
mikeassk Goldmember 2,329 posts Likes: 3 Joined Aug 2006 Location: San Diego/ San Fran/ Berkeley More info | Mar 24, 2011 04:20 | #4 Using a monopod/tripod greatly assists certain styles of shooting. Photography is not weightlifting, so I dont understand what your talking about here?
Anderson-Photography Senior Member 709 posts Likes: 2 Joined Jul 2007 More info | Mar 24, 2011 09:13 | #5 The 400 5.6 is definitely not a heavy lens to handhold but I can see why some might use a monopod. At 400 mm the angle of view is very narrow and without IS even the slightly camera shake can cause soft images. Plus, your post mentions he is a writer and not a photographer. Maybe he had to cover an event a photographer couldn't make and he is unfamiliar with ISO, metering and shutter speed he may not be using a high enough shutter speed to stop action, or, he may be using a slow sutter speed to pan the action and get significant background blur. Chris Anderson
frederiksenp Senior Member 607 posts Likes: 16 Joined Nov 2008 Location: Baltimore, MD More info | Mar 24, 2011 09:13 | #6 Sure, it looks a little silly, but after 2 hours, holding anything up is going to get heavy. Baltimore, MD Photographer | Sports Photographer | Canon 6D | Canon 7D | 70-200 f2.8 | 17-40 f/4 | 40 f/2.8 | 85 f/1.2 | 50 f/1.4 | Sigma 120-300 f/2.8
thekid17 Senior Member 984 posts Likes: 2 Joined Feb 2007 More info | why worry about holding the camera still when u can use a monopod and get well taken photo
asysin2leads I'm kissing arse 6,329 posts Likes: 3 Joined Dec 2006 Location: Lebanon, OH More info | Mar 24, 2011 11:29 | #8 Cozmocha wrote in post #12081361 It's a 400 5.6 I thought the hood on the 400 5.6 was a big larger. I could be wrong, of course. There's a first time for everything, you know. Kevin
Mar 24, 2011 12:37 | #9 Matt-EM wrote in post #12081310 Just thought I might post this random shot I took at an event I covered on the weekend. This bloke writes for a national regional newspaper. I guess this lens is a little too heavy to hold. I must say though it looks like a mini 400mm. I doubt weight has anything to do with it. More likely a choice around trying to get the best quality shot. Gear List
Anderson-Photography Senior Member 709 posts Likes: 2 Joined Jul 2007 More info | Mar 24, 2011 13:10 | #10 asysin2leads wrote in post #12083540 I thought the hood on the 400 5.6 was a big larger. I could be wrong, of course. There's a first time for everything, you know. Does he have an extender on it, too?The hood on a 400 5.6 is attached to the lens and of the push-pull type. He appears to have it retracted in the photograph. Chris Anderson
larrygasinski Hatchling 5 posts Joined Jul 2010 Location: Santa Clarita, CA More info | Mar 24, 2011 13:18 | #11 If that's a 400, and if he's using a crop body the effective length is 640mm. Would you expect to get a sharp image hand holding a 640mm lens - especially if you had to crop the finished image fairly tight? I wouldn't. Even a 300 on a crop is 480mm. Website: www.SCVPhoto.net
Brikwall Senior Member 840 posts Likes: 1 Joined Apr 2007 Location: Atlantic Canada More info | Mar 24, 2011 15:15 | #12 I've seen people with Rebels and kit lenses, and even with point-and-shoots, using monopods. I watched one guy shoot a hockey game using a tripod with 3-way head to support his DSLR and kit lens. I asked if he was doing video but he said "No, stills." I chuckled to myself about it but later overheard him say that he thought I was nuts for using a 1D3 and 70-200/2.8 handheld. To each their own. Dan
larrygasinski Hatchling 5 posts Joined Jul 2010 Location: Santa Clarita, CA More info | Mar 24, 2011 16:02 | #13 The funniest I saw was someone at a HS football game with a small camcorder on a monopod....but she held it up off the ground while shooting, then rested the pod on the ground between plays. I guess that tiny camcorder was too heavy to hold....either that, or there was an invisible air cushion under the pod. Website: www.SCVPhoto.net
Mar 24, 2011 17:00 | #14 That does look funny. However, show me your photos, not your gear. THAT's what matters! My pictures: John Wilke Photography
kirish Member 228 posts Likes: 9 Joined Jun 2009 Location: Cypress, CA More info | Mar 24, 2011 18:03 | #15 I think he's just a big guy that makes the lens look small. If the Mayans taught us anything, its if you don't finish something its not the end of the world.
| Latest registered member is Frankie Frankenberry 1487 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
