I had an impression that sometimes when the issue is not very serious, some technicians simply log some work not actually doing anyting. three times I received the lens exactly in the state I sent them, even though there was a lot of things on the work order. The very last time I received my 70-200 which I sent for an unrelated issue. The lens focused prefectly, maybe one centimeter backfocusing on 5 meters distance, which for me is perfect.
The work order says they adjusted the focus ( I did not ask for it ! ) And the focus is... 1 centimeter backfocus on 5 meters distance ! Definitely something is phishy here. At the same time I asked to check out the sound that was coming from IS. I did not insist on fixing it just to confirm that it was normal. They work order says they replaced the IS but the sound is the same.
. I had to go through the trouble of opening a claim with BBB to go through.
